Dropper post help- Mtbr.com
Results 1 to 3 of 3
    czm
    czm is offline
    Apr 2019
    Dropper post help
    HI all
    I have a Canyon Spectral cf 9.0 sl 2018 which as the ROCKSHOX Reverb Stealth dropper.
    It is a Medium Frame and the dropper is 150mm I think, when it is fully up it feels a tiny but stretched when peddling- I have it at its lowest point in the frame. If I wanted to swap it over to something a bit shorter should I be taking note of the travel measurement and/or post length on the Rockshox website here:
    https://www.sram.com/en/rockshox/models/sp-rvb-s-c1
    I know it may seem a silly question but can’t get my head around it?
    Always in the wrong gear
    Reputation: Impetus's Avatar
    Aug 2014
    A 125mm dropper will give you more room to adjust your seat position
    Shiftin' jumps and huckin' gears
    Reputation: RS VR6's Avatar
    Does the post come with a Connectamajig? If it does...you can go with the shorter non Connectamajig fitting. That might get you a few more MM's of insertion. Otherwise...not sure how you would get around a post that's too long. Only other way to get around it is to sell the Reverb and get a post with a shorter body. That's what I had to do with a recent Ibis purchase.
  1. Replies: 3
    Last Post: 08-28-2018, 12:05 AM
  2. Replies: 2
    Last Post: 01-07-2017, 12:10 PM
  3. Replies: 29
    Last Post: 07-01-2016, 02:56 PM
  4. Replies: 5
    Last Post: 01-10-2016, 10:58 AM
  5. Help me finish my Mach 6 (Dropper Post Post)
    By trickbooter in forum Pivot Cycles
    Last Post: 05-28-2014, 11:34 AM
Members who have read this thread: 29
