Results 1 to 12 of 12
    do you lube the base of your dropper post?
    I've put some Slick Honey on my dropper post but it feels like I should spray some lube at the base of the dropper around the opening to help reduce friction around the metal-on-metal contact area. Do you lube the base of your dropper post? If so then what products and techniques do you recommend?
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by titus View Post
    IME, that allows contaminates picked up by the lube to work their way into the post.
    Oct 2018
    If you mean the extension, the actual seat post -yes I do.
    After it's been washed I spay WD40 Silicon Spray on a towel, or a very light amount on the post and use the rag to wipe it around the post leaving a film behind. I then cycle it through the range and put the bike away.
    I think grease would attract too much dust for my liking.
    I've serviced the Specialized Command Post once and used slick honey on the bottom half, the seals and the inserted portion.
    Sep 2014
    The collar on mine unscrews and I pack grease under that, makes a big difference. I dont bother with doing the outside since the seal will just keep it out.
    Reputation: sturge's Avatar
    Fairly new to droppers but I give mating surfaces a squirt of silicone spray every now and then after cleaning then wipe it off. Have done the same with fork and shock for years. It leaves a dry slick film that does not attract dirt.
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...
    Oct 2018
    The advantage in lubricating the post (or fork stantions) is reducing stiction. There isn't metal/metal contact. The seal is snug, of course, and reducing friction on the seal is good preventative maintenance for longevity.
    Just use caution with spray lubes so over spray doesn't land on the rotor.
    May 2017
    Isn't the OP talking about the base of the post and the actuating mechanism not the stanchion?
    For me it would depend on the mechanism but a little spray of silicon lube would do no harm. I wouldn't be covering it in grease.
    Reputation: Jack Burns's Avatar
    I imagine the manufacturer recommends greasing the post.
    It would really suck to have a suspension post seized in a seat tube.
    Sent from my LG-H910 using Tapatalk
    Reputation: LyNx's Avatar
    Don't understand WTF the OP is talking about, but for me and droppers, it goes like this....carbon assembly paste in the ST and lower part of the post to help reduce the need to crank down on the seat clamp. On the stanchion, a light smearing of grease, then cycle the post a few times, then wipe off, as any lube will attract dirt. A couple times a year I loosen the collar and slide it up the stanchion, clean it out and re-grease. All this on a 9point8 FallLine post.
    Sep 2018
    +1 to this. Carbon assembly paste is great for this purpose.
    Reputation: fredcook's Avatar
    If the OP means lubing during post installation, I just use light grease to prevent seizing. Non carbon, btw.
    If lubing for daily ride use... my current dropper has a rubber water/weather rubber cover at the base, which I pull up and apply a little Tri-Flow on the seal, then reset the rubber cover. On older droppers, I just put the same Tri-Flow around the base seal. Sure, it might collect dusk, but no worse than the forks or rear shock, which also get the Tri-Flow treatment.
    You didn't quit riding because you're old, you're old because you quit riding.
    Reputation: RS VR6's Avatar
    I don't use lube of any kind on the dropper stanchion. If you're talking about the post and seat tube..I use a very small amount of friction paste.
  1. Dropper Post Data Base?
    By gmats in forum Components
    Last Post: 08-08-2018, 10:26 PM
  2. Base miles or no base miles?
    By Lenny7 in forum Endurance XC Racing
    Last Post: 10-25-2017, 08:55 AM
  3. How much base is considered a good base?
    By string_wise in forum XC Racing and Training
    Last Post: 12-06-2011, 12:03 PM
  4. Lube Lube Lube...
    By PimpinD in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 06-15-2008, 05:50 AM
  5. Rockhopper (base), GFisher Marlin (base), or something else?
    By roker in forum Bike and Frame discussion
    Last Post: 08-18-2006, 09:17 AM
Members who have read this thread: 111
