Creak in either Pedal or BottomBracket or Crank Arm?- Mtbr.com
    Apr 2019
    Im new to bikes etc but I have this terrible creak in what I thought was my LH pedal, so I removed it cleaned threads on crank and pedal, degreased and its still creaking under load. There is a little bit of play in the pedal. However I tried a different pedal also and there is a bit of play in that too, and its making the same noise under load... a bit confused as to what the problem is if both pedals are making the same noise, I'm thinking maybe its somewhere else on the bike. As I said though I am quite new and also confused, any ideas would be greatly appreciated.
    Reputation: fredcook's Avatar
    Since you're "new to bikes", you may not know, but do you have a press fit or threaded bottom bracket (BB)? Creaks under load can be common with the BB. The approach to address BB creak is a little different for each. At the very least, and as a first step, clean around the BB with a brush. For me, that fixes creaks most of the time.
    You didn't quit riding because you're old, you're old because you quit riding.
    Jul 2015
    Make a check list start living parts one by one, pedals cranks, pivots, etc process of elimination, do bb last, it's the toughest
    Sent from my XT1585 using Tapatalk
    Jun 2016
    I'd actually start investigating the saddle.
  1. Replies: 23
    Last Post: 12-10-2014, 08:51 AM
  2. i-drive creak creak creak
    By slo65 in forum GT
    Last Post: 04-18-2011, 07:54 AM
  3. Replies: 46
    Last Post: 05-28-2009, 09:57 AM
  4. Creak...Creak...Creak
    By lucero in forum Singlespeed
    Last Post: 03-17-2007, 06:56 PM
  5. creak creak creak
    By bikecop in forum 29er Bikes
    Last Post: 09-14-2005, 09:17 PM
Members who have read this thread: 25
