Crankbrothers cleats/pedals with shim and shield: can't keep them tight!- Mtbr.com
Results 1 to 7 of 7
    Reputation: hanshananigan's Avatar
    I have the cleats on Shimano shoes and using Candys.
    Unclipping can rotate the cleat hardware between the shoe and the shim, while the bolts are relatively tight. Happens every other ride at least. I use anti-seize compound on the threads. Should I try blue/red Loctite instead? Should I scuff the surface of the shoe under the shim?
    Hi!
    Style: Mid-Atlantic roots, rocks, & poison ivy
    Reputation: Lone Rager's Avatar
    Dec 2013
    Grease the threads and torque to 5Nm. That's likely tighter than what you're currently using. A torque wrench is good but a torque key is handier. Be careful to not strip the heads. If it's still slipping then, let us know.
    What, me worry?
    HHL
    HHL is offline
    Que je suis bete!
    I don't know if this is still true, but CB used to ship two lengths of screw. If you are using the long one, it may feel tight, but not really be tight against the cleat.
    Quote Originally Posted by Lone Rager View Post
    I've been trying to avoid spending ~$50 for a (adjustable) torque wrench/key but it is probably worth it. Thanks for the response.
    Hi!
    Quote Originally Posted by HHL View Post
    Thanks for the response. They still do that. Why would the longer one feel tighter than it might be?
    Hi!
    Reputation: MSU Alum's Avatar
    Quote Originally Posted by hanshananigan View Post
    Because it bottoms out, before it can put pressure on the cleat.
    Quote Originally Posted by MSU Alum View Post
    Gotcha - thanks. The design of these shoes won't allow for bottoming out, but that is a good consideration for others .
    Hi!
  1. Replies: 1
    Last Post: 03-30-2018, 01:13 PM
  2. SPD cleats are SPD cleats are SPD cleats or are they?
    By far raider in forum General Discussion
    Last Post: 11-03-2012, 12:49 PM
  3. Cleats Cleats & more Cleats...
    By TheSubaruJunkie in forum Beginner's Corner
    Last Post: 04-10-2008, 11:43 AM
  4. Crankbrothers cleats with B and C instead of circles?
    By Danish Dynamite in forum General Discussion
    Last Post: 06-02-2006, 01:38 PM
  5. Crunchy Crankbrothers Cleats
    By drgonzo in forum General Discussion
    Last Post: 05-11-2006, 06:46 AM
Members who have read this thread: 20
