Cracked carbon bars- Mtbr.com
Results 1 to 14 of 14
    Oct 2018
    Cracked carbon bars
    Had a pretty big crash on my 2019 Canyon Neuron. Bent the bars pretty good but otherwise bike seems ok. Bought some Box carbon bars to replace the bent Iridium bars and they cracked in the stem when tightened. They were installed correctly with carbon paste and using torque wrench with a stepped sequence. 5 Nm is all that was applied (Box said max is 7 Nm). Was not overtightened or tightened on one side.
    What gives?
    Reputation: SoDakSooner's Avatar
    I'd be calling Box.....
    Reputation: Lone Rager's Avatar
    Dec 2013
    Got any pics? A few years ago I had some bars that had a decal under clearcoat and the stem clamp smooshed the decal/clearcoat making it look like the carbon cracked.
    Do the math.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by sharkynrk View Post
    What gives?
    How was the torque wrench calibrated?
    Oct 2018
    The clicker torque wrench was calibrated by the manufacturer but I verified it with a beam style torque wrench as well. I submitted a claim to Box. Havenít heard back. Iíll post pics tomorrow.
    The hole in the stem might not be round. Take an old al handlebar and spot the stem with some valve grinding compound. Betcha the hole is imperfect.
    lean forward
    Oct 2018
    Oct 2018
    ^^ I slid the bar out to the right to take the picture, but the bar was centered when installed.
    Wanna ride bikes?
    Oct 2013
    Was the stem, hardware, or faceplate damaged from the last crash? Any minor bend could easily create a hot spot and wreck the carbon bar.
    I would never torque a carbon bar to 7nm. That's way too high and completely unnecessary. 4nm is probably sufficient, 5 max.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Oct 2018
    yeah 7nm is what Box said, 5 is all the higher I went. I didn't see any damage or issue with the stem - the original bars bent out toward the end. I also checked the mating surfaces prior to installation and noticed nothing out of the ordinary.
    Oct 2018
    haven't heard from box yet
    Jul 2019
    I never torque carbon bars, one should only go a hair past where you cannot twist it by hand in neck.
    As for your case, bar sure does look thin where the crack is, and it also looks like a hot spot pushed it in
    Go to the auto parts store and buy the smallest container of the finest grit valve grinding compound they sell. Spot the stem and see whatcha got. It will tell ya how round the hole is and any high spots that might be. I have spotted all the stems I have ever bought and none were very good out of the box. If ya work it enough ya can remove the high spots and even make the hole round.
    lean forward
    Oct 2018
    I will definitely try that with lapping compound and the old bent bar before putting any new bars back in the stem. I am quite surprised that a hotspot that is small enough to be removed with valve lapping compound could do that to a bar under so little clamping force, but obviously it can be an issue as I am learning.
  1. Cracked carbon bars?
    By JHANguyen in forum Weight Weenies
    Last Post: 04-02-2011, 03:38 PM
  2. Carbon bars vs. Alu bars (long)
    By ddraewwg in forum Ibis
    Last Post: 04-25-2008, 09:00 PM
  3. X-post: Carbon Bars vs. Alu Bars
    By ddraewwg in forum General Discussion
    Last Post: 04-08-2008, 08:51 AM
  4. Aluminum bars are colder than carbon fiber bars.
    By KRob in forum General Discussion
    Last Post: 01-13-2006, 12:49 AM
  5. bars bars bars....
    By JBsoxB in forum Downhill - Freeride
    Last Post: 12-01-2005, 10:21 PM
Members who have read this thread: 114
