Carbon Handlebars - Will I need to use carbon paste?- Mtbr.com
Results 1 to 13 of 13
    Apr 2019
    Recently purchased new handlebars which are carbon, never had carbon bars before. Will I need to use any carbon assembly paste on the bars when fitting to the stem?
    Jul 2017
    Short answer is yes.
    Apr 2019
    Thanks champ.
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    Most probably yes.
    Reputation: LyNx's Avatar
    Always a good idea, that way no need to over tighten anything in the least. Don't only use it on the stem/bar interface, also use it between bar and controls so you don't have to crank them down more than needed to stop them rotating under normal use, but not so tight that they won't spin/move in a crash. Controls=shifters, brakes, grips.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    Reputation: Lone Rager's Avatar
    Dec 2013
    No. Clean the interface between the clamp and bar. Torque the clamp to spec. The only place I (and the LBS) routinely use carbon paste is on seatposts in carbon frames or carbon seatposts. Look at the user sheet that comes with the bars and see what their recommendation is.
    Do the math.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    It's a good idea, it puts a barrier between aluminum and carbon, which has the potential to corrode due to galvanic corrosion, plus as everyone else said, it helps to reduce the torque you have to use.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    you need a torque wrench for sure
    paste, maybe on the stem
    paste won't hurt but may not be needed
    fyi I used paste on stem and everything clamped to the bars as the handlebar manufacturer said to use paste (tacx carbon assembly compound)
    but accurate and repeatable torque will help the bar live longest w/o dumb cracks from overtightening
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Reputation: DethWshBkr's Avatar
    I have never needed carbon paste on anything except a seat tube.
    Every carbon bar I've ever had though has a rough center.
    I DO torque carbon steerer and bars though. Usually 5nm
    Reputation: Mr Pig's Avatar
    A lost a few hours last year trying to get a, alloy seatpost out of a carbon frame. To this day it is still stuck fast. So to answer the question with another question, why the hell not??
    Reputation: jeremy3220's Avatar
    Jul 2017
    Quote Originally Posted by Mr Pig View Post
    Agreed. A lot of people say they don't need carbon paste on the bars but both carbon bars I've had needed paste just to keep the brake lever from slipping at 5nm. I found out on the trail that it wasn't going to work without paste. I don't care if people say they don't need it.
    Reputation: RS VR6's Avatar
    I've never had the need to use it. I just clean the mating surfaces and torque to spec.
    Jul 2015
    Quote Originally Posted by Lone Rager View Post
    Yes
    Sent from my XT1585 using Tapatalk
  1. Replies: 1
    Last Post: 10-26-2013, 10:10 PM
  2. Replies: 10
    Last Post: 05-11-2013, 12:37 PM
  3. Replies: 2
    Last Post: 01-19-2013, 03:29 AM
  4. Replies: 14
    Last Post: 04-20-2012, 09:55 PM
  5. Replies: 6
    Last Post: 10-12-2011, 08:50 AM
Members who have read this thread: 10
