Carbon Handlebar Options 50mm Rise or Greater- Mtbr.com
Results 1 to 6 of 6
    So far I have found Enve bars with a rise of 50mm or greater. Looking to see if there are any other options. Wouldn’t mind even a little more rise. I’m only looking for carbon options. I have found plenty of aluminum options, but Enve is the only carbon option I have found thus far. If there are any others, please post. Thanks for the help!
    Enve would be pricey.
    How about an adjustable up to 60* stem to contribute some rise?
    https://www.ebay.com/itm/25-4-31-8-9...Bw3jvEO_zJP34Q
    Reputation: bcriverjunky's Avatar
    Jul 2014
    Bucksaw, Farley, and a Sturgis....
    Nov 2017
    I agree that adjustable stems are best avoided, but there are any number of decent riser stems with 17, 25, 30, 35 or even 45 degree rise angles. The 45s I've seen tend to be 200+ gram boat anchors, but Uno makes some good 35 degree stems in 70, 90 and 110mm lengths that are easily found on Ebay for under $20.
    Look over the above ideas.
    If you can use one then you're looking at the whole range of bar options at all prices.
    Pick whatever you like.
    Reputation: RS VR6's Avatar
    Spank has a Vibrocore bar that is 50mm in rise. I know you said carbon...but if you're looking for comfort by the way of carbon...the Vibrocore bar will damp vibrations similar to carbon.
  1. stem rise vs. handlebar rise?
    By allrachet in forum 29er Components
    Last Post: 01-11-2013, 07:09 AM
  2. Negative Rise 50mm Stem
    By Dango Dog in forum 29er Components
    Last Post: 04-07-2012, 05:24 AM
  3. Replies: 0
    Last Post: 06-13-2008, 01:49 PM
  4. Replies: 1
    Last Post: 06-01-2005, 11:58 PM
  5. Thomson 50mm or azonic shorty 50mm
    By bullcrew in forum Downhill - Freeride
    Last Post: 01-23-2005, 12:49 AM
