Bottom Bracket for Rotor 2inPower MTB- Mtbr.com
Results 1 to 2 of 2
    Apr 2020
    Hi,
    I'm currently riding a Scott Scale 700 RC World Cup from 2017 using the following bottom bracket: Sram GXP PF integrated / shell 41x92mm.
    There's a lot of creaks coming from the bottom bracket and having read online how bad the GXP system is, it is time to go all-in.
    I'm therefore considering getting a Rotor 2INPOWER DM MTB Power meter but unsure about the bottom bracket to go with it.
    Will a BB92 30mm bottom bracket fit? If yes, any recommendations?
    Reputation: Lone Rager's Avatar
    Dec 2013
    GXP is a spindle spec. It works fine and there's nothing wrong with it. The problem in your case is the PF BB, which is a frame shell spec and can be problematic wrt creaking and longevity.
    So, you'll need a BB that fits a 30mm spindle and your PF frame shell. This is a marginal situation as there's not enough room in the PF shell to fit reasonably sized bearings between the shell and a 30mm spindle. The balls will have to be small. Some manufacturers offer dual row bearings for this application as a means of mitigating this issue.
    I'm running a RF Cinch PF x 30mm BB pn BB19BB899230DR. This is a relatively inexpensive dual row BB. It's been working well for me so far. There are other more expensive options. Check Wheels Manufacturing and BB Infinite.
    https://www.bbinfinite.com/pages/mountain-30mm-spindles
    What, me worry?
  1. Threaded bottom bracket (2019 Stumpjumper): Want carbon crank with bottom bracket
    By rakerdeal in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-27-2020, 08:03 AM
  2. quarq dzero xx1 vs rotor 2inpower
    By louit32 in forum XC Racing and Training
    Last Post: 12-22-2018, 11:12 AM
  3. Using Bottom Bracket Wrench vs. Bottom Bracket Socket
    By BobaX in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-21-2016, 10:36 PM
  4. Replacing a Shimano MTB HT II bottom bracket with a Shimano Road HT II bottom bracket
    By AndrwSwitch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 11:58 AM
  5. A rotor is a rotor is a rotor... wait, right?
    By phUnk in forum Brake Time
    Last Post: 05-21-2004, 01:09 PM
