Bit of Wiggle between head tube and fork. Ok?- Mtbr.com
Results 1 to 9 of 9
    Jul 2015
    It seems the connection between the head tube and the fork (see red arrow in photo) has the tiniest bit of wiggle that I can certainly hear rattle when I'm riding on a bumpy trail or dropping my bike from a foot high onto the garage floor. Is that a problem? I don't remember if it was like this before. About 2 months ago I loosened the headset bolt at the center top to replace a spacer with a WeeRide spacer (kids bike seat). I'm wondering if I did something wrong. But I remember that head tube bolt was very tight and I made sure to tighten it very tight. So is this a problem, and how to fix it? Do I need to re-tighten one of the headset bolts (with yellow arrows pointing to them)?
    Attached Thumbnails Attached Thumbnails Bit of Wiggle between head tube and fork. Ok?-2020-07-06-46-51.png
    Cycologist
    Reputation: chazpat's Avatar
    It sounds like a loose headset. It's not just a matter of tightening the bolts on the stem, that just makes it tighter on the fork's steer tube; you've got a slight gap between the stem/spacers/headset. You'll need to loosen those bolts on the stem, then use the bolt in the cap on the very top of the steer tube to preload the headset. You should take that slack out but not tighten it so much that the fork does not turn smoothly. Once you have it properly tensioned, then you tighten the stem bolts, after being sure the stem and spacers are all the way down on the steer tube. Once that is done, I loosen the top bolt a little, the stem and bar should be held on by the stem tightened to the steer tube, not that bolt.
    Watch some youtube videos.
    This post is a natural product. Variances in spelling & grammar should be appreciated as part of its character & beauty.
    Cycologist
    Is the wee ride spacer the same height as the spacer it replaced?
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    No, loose bearings/parts is never ok. The problems only get worse with time and ultimately lead to failure.
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    You might be bottoming out the top cap before it provides enough clamp. Either file a couple mm off your steerer or add a slightly thicker spacer.
    Santa Cruz Tallboy 4
    Jul 2019
    STOP its not OK take it a part and inspect what exactly the problem is. right now your guessing
    Jul 2019
    loosen the two bolts you have listed with the lower yellow arrows
    then tighten the top yellow arrow which will tighten the play, you describe
    Sep 2014
    Ibis Ripmo V2
    Ibis Ripley V4
    Pivot Mach 4SL
    Pivot LES SS
    A road bike
    Jan 2009
    remove your top cap and look inside the stem/ steerer tube. how much space is there between the top of the fork steerer tube and the stem that is clamped onto it? there should be less than 5mm of space there, but at least 1mm.
  1. Seat tube, top tube, head tube deal
    By calstar in forum Frame Building
    Last Post: 08-29-2013, 10:12 AM
  2. Tiny bit of play in head tube
    By sinkoman in forum Urban/DJ/Park
    Last Post: 08-10-2008, 07:21 AM
  3. Freehub wiggle? Ok or not?
    By filthyrob in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-29-2006, 09:50 AM
  4. Replies: 0
    Last Post: 03-20-2006, 10:40 AM
  5. Wiggle between Hub and Cogset
    By wXman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-01-2005, 09:53 PM
Members who have read this thread: 48
