Alt bars, who likes?- Mtbr.com
Results 1 to 20 of 20
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Over the past year or so, it seems my arm/elbow pain had slowly been getting worse. Maybe it's just that I'm 40 now.
    But my bikes are cushy (fatbikes and plus bike) both with suspension forks).
    I'm going to try an alt bar for the first time. Ordered a Carver myti carbon. Should be here in a few days.
    Anyone else using"crooked" handlebars and like or dislike?
    Sent from my SM-G960U using Tapatalk
    Reputation: bcriverjunky's Avatar
    Jul 2014
    You should check out SQlab 30x bars.
    Bucksaw, Farley, and a Sturgis....
    Feb 2006
    I have an Easton 35mm bar (maybe too stiff?) With I think 9 degrees of back sweep.
    Will see if the Carver is too much angle or not.
    Jul 2014
    My hands used to go numb. Raised the bars level with the seat and went with 16* sweep back.
    Reputation: AluminumMonster's Avatar
    I tried Jones bars on a bike I borrowed. I thought they looked weird and would feel awkward, but I ended up really liking them. I have them on my fat bike now. The only problem I have is on tight, low speed turns. They bump my legs sooner than straight bars, so I have to plan a little more. Other than that they feel more comfortable and stable to me.
    Jul 2014
    I have the Answer 20/20 bars and like them.
    https://shop.hayesperformance.com/co...mm-width-black
    Ripley LS v3
    OG Ripley v2 handed down to son
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    I have had a long history with alt bars and it all stemmed from riding singlespeed and rigid. I started with the Fleegle bars from On-One, which were ok but didn't have enough backsweep for me. I moved to the Mary bars also from On-one and felt like this was the sweet spot for me. I rode huge mileage on rigid 26" singlespeeds and then rigid 29" geared bikes all over Arizona, fast and rocky.
    I could ride for hours on end and not have sore hands. Calluses and blisters would come and go but that was mostly the impact of riding with gloves in Arizona and twisting the bars for control on the rocky descents and ascents and sweaty hands.
    I tried the salsa bar, can't recall what that was called, then bought a Jones bar with Jones Diamond bike and loved it even more. I rode Arizona for a couple of years on it and it never hindered me and I found my hands were more comfortable. Then I moved to Washington and found that I can use them just as well on skinnies, drops, and jump lines. Still like having them, just about out of my 40's and started using alt bars before I began this decade. If I moved to a full suspension bike, I might try a big wide bar but they feel weird to me now and I am not sure I could do it.
    MTBR Posting Guidelines
    calories>electrons
    Feb 2006
    Thanks all!
    Feb 2006
    Got the new bars put on, slightly more narrow but close enough, quite an angle difference.
    Going for an easy road ride around the lake this afternoon to see how they feel before hitting the trail.
    Excited!
    Reputation: Johnny Chicken Bones's Avatar
    Yep. As others have written- they can be great.
    I've used several what would be called mustache bars.
    The more comfortable- the worse they are (for me anyway) when the riding gets super rough.
    We run plenty of sweep on our touring bikes. Seating position is more upright. Neck feels better and I see more of the world passing around me.
    Longer days? Great. I'm so much happier than w/ the standard drop bar set ups.
    But hand numbness? I can't seem to get a grip on that w/ my riding.
    I've had trips w/ long arduous days and the hands are fine. I've had smooth easy stuff and there's a dead finger or two for months.
    Even when I think the terrain is forcing me to be more dynamic in my riding, i've had numbness issues. Thin gloves, padded gloves.
    Lots of sweep. Less sweep. It still comes and goes. Mostly it goes. The issue isn't always there.
    If you are riding lots of chunky spicy terrain, a bar w/ lots of sweep wouldn't be my first choice, or my first recommendation but there are plenty fast folks that say otherwise.
    But- that straight broom stick that so many companies are making? It's no wonder that so many folks drive to the trailheads. I wouldn't want to ride their bikes very far either!
    I'll be curious to hear what you think about them.
    --------- __o
    ------- _`\<,_
    Running is for prey.
    Feb 2006
    So far so good, they are comfy on the trails and no problems going through the rocks (yet).
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    If elbow issues were the problem, swept bars are as good of a place to start as any.
    Once you get the reach/tilt dialed, consider some sort of ergo/paddle grip. They allow you to more loosely rest your hands on the grips instead of having to have fingers wrapped and clenching. Relaxing your forearm muscles for a greater % of the ride is the goal.
    Jan 2009
    I went with a SQLabs 12 degree handlebar. it has some upsweep and minimal rise. I tried going back to a conventional 9 degree low riser bar and it was a bit uncomfortable. I don't want to turn my bike into a beach cruiser, upright position, so 12 degrees and 760mm wide is just enough to make the position comfortable but I still feel in control. I tried 20/20 and a few other odd-shaped handlbars and this is the sweet spot for now.
    Quote Originally Posted by mack_turtle View Post
    Do you still have the 20/20 that you might want to sell?
    Ripley LS v3
    Aug 2003
    Quote Originally Posted by TwoTone View Post
    I have a set I'd part with. You know how to reach me.
    Quote Originally Posted by mikesee View Post
    780mm?
    Ripley LS v3
    Aug 2003
    780mm?
    Best I can tell, those never actually existed.
    Yea they have them now. I have the 720s and recently found out they added 780.
    They're on sale if you want a pair.
    https://hayesbicycle.com/products/pr...32139589386285
    Just went ahead and ordered myself some.
    Ripley LS v3
    Reputation: Hobine's Avatar
    Quote Originally Posted by Shark View Post
    Not only the same bars, but it looks like the same bike too.
    I love the Carver bars. Elbow pain is gone.
  1. Music Thread: alt. pop/rock, post punk, alt. indie rock, synth pop
    By Boris Badenov in forum Off Camber (off topic)
    Last Post: 11-16-2017, 08:11 PM
  2. Rocky's Alt 750 MSL 2014 vs. Alt 750 (Non-MSL) 2016
    By eyalriemer in forum All Mountain
    Last Post: 08-07-2017, 01:32 AM
  3. The boy likes it, he really likes it.
    By sachase in forum Families and Riding with Kids
    Last Post: 02-05-2013, 07:32 AM
  4. Pogies and Alt-bars
    By JAGI410 in forum Fat bikes
    Last Post: 12-14-2011, 04:06 AM
  5. what alt bars work with road levers?
    By mack_turtle in forum Commuting
    Last Post: 09-16-2011, 06:11 PM
Members who have read this thread: 70
