Are all cane creek headset bearings the same?? Going from external headset to IS- Mtbr.com
Results 1 to 8 of 8
    Dec 2004
    My old frame has a CC headset that's ZS44 upper and EC49 bottom. So tapered steerer.
    My new frame needs a 1-1/8 upper bearing and a 1.5" lower bearing. So IS 41/28.6 and IS 52/40. This is for a Santa Cruz frame.
    I know the bearings will fit fine...but is possible to convert an external headset into an IS headset by just not using the headset cups???
    Intense 951 Evo and Santa Cruz Megatower
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by Christopher Robin View Post
    Uhhh, no. You can't just "not use" the headset cups if your frame requires headset cups.
    There are structural differences in the frame between IS and pressed cup types. IS headsets use the frame to support the bearings, whereas pressed cup types use the pressed cups to support the bearings. If you did what you wanted, there'd be nothing to support the bearings and no way to properly preload them.
    https://www.parktool.com/blog/repair...dset-standards
    Reputation: Lone Rager's Avatar
    Dec 2013
    ^^^ that's how I first read it, but after re-reading it, I believe he is asking if he can use the parts from an external headset, except the cups, on an integrated headset frame. It sounds plausible, but IDK for a fact.
    Do the math.
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    OP, check the bearings numbers, if they match you can use them.
    since 4/10/2009
    Quote Originally Posted by Lone Rager View Post
    Ah, if that's the case, then yeah.
    Quote Originally Posted by Aglo View Post
    Yep
    Dec 2004
    Haha yeah I didn't quite word that clearly...
    Looks like the bottom bearing fits fine in the new frame, and the crown race looks like it seals it up as if the bearing was sitting in an actual headset cup. The top bearing sticks out a bit above the headtube in the new frame so top cap doesn't seal it up. So I'll have to look into that...I'll probably just go to the shop down the street and let them figure it out.
    Dec 2013
    Yeah. Headsets can get pretty complicated. There are 5 dimensions for a headset bearing that need to match the application: ID, OD, thickness, inner chamfer angle and outer chamfer angle (36 or 45 degrees). And those things are different for the top and bottom bearings. (There are actually two more, the depth of the chamfers, but I've never seen these specified.)
    Chamfer angle is important and not easy to check. A bearing with the wrong angle can still seem to fit and work properly but it can cause problems further on. Nowadays, headtube contact angles are all 45 degrees as 36 has fallen by the wayside.
    Do the math.
    When you find replacement bearings do yourself a favor and pop off the seals and top off both sides with water proof grease. After reinstalling the seals make sure you coat those liberally with waterproof grease as well.
    Those bearings don't really seal that well, one wet ride and they will get water intrusion if they aren't topped off and have the extra grease to reduce intrusion.
    83 Ritchey Everest
    95 Bianchi Mega Tube ti
    2015 Kona Operator Supreme
    2015 Kona Process 153
    2019 Kona Process 153 CR 29
  1. Replies: 1
    Last Post: 02-06-2019, 06:18 PM
  2. Issues with Cane Creek 40 Lower Headset Bearings?
    By 755872 in forum 29er Components
    Last Post: 10-01-2018, 03:47 PM
  3. Did Cane Creek Change the 110 Headset Bearings?
    By Thrawn in forum Components
    Last Post: 03-09-2016, 08:13 PM
  4. Replies: 7
    Last Post: 03-13-2014, 06:24 AM
  5. Replies: 10
    Last Post: 10-03-2005, 10:38 PM
Members who have read this thread: 62
