9point8 Slack-R- Mtbr.com
Results 1 to 7 of 7
Thread: 9point8 Slack-R
    Sep 2018
    9point8 Slack-R
    Looks like that finally there is a way to change the HTA for integrated headset.
    Did someone already tried this? if so, please share your thoughts.
    https://intl.9point8.ca/index.php?ro...product_id=261
    Also, will this going to work with Bronson v3?
    May 2015
    Tempted to get one for my sensor.
    Ah damn it, upper hs is is42. I'm a whole mm out.
    Aug 2016
    I just ordered one to put on my 2020 custom timber jack. Hoping to ride it in the next week or so. I had some reservations about it creaking over time but the way itís designed to fill the entire HT and how the parts screw into each other is reassuring. But if it works it will be an ideal upgrade for the timber jack, since the stock frame HT angle is 67.5.
    Sep 2019
    Quote Originally Posted by pinetree View Post
    Assemble it with carbon assembly paste and loctite, basically following instructions, and it's unlikely to creak. I installed one a couple of evenings ago and it seems rock solid in my 90mm headtube.
    Reputation: RS VR6's Avatar
    Looks like a nice piece. You'd have to make sure that you have enough steerer to use it. None of my forks have enough steerer to use it.
    FYI,
    Check the inside of your headtube before you buy one of these. I tried to install it in a Stache carbon hardtail, 15.5", and the middle piece wouldn't clear the inside of the headtube because Trek put a kind of chin on the front of the headtube that barely clears the steerer tube, but not the slackr.
    Oct 2016
    Quote Originally Posted by Gilarider View Post
    FYI,
    Yep, I learned of this after watching this installation on YouTube: https://youtu.be/PRYIzYa7mxg
    This appears to be an issue on many bikes and 9point8 now has a disclaimer about it on their site.
    I'm not comfortable sanding away carbon from my frame so unfortunately this will be a no-go for me.
  1. 9point8 SLACK-R - IS angle-set
    By GT87 in forum Santa Cruz
    Last Post: 1 Week Ago, 07:02 AM
  2. Replies: 16
    Last Post: 03-24-2018, 03:54 PM
  3. 9point8 new dropper post???
    By shirk in forum Components
    Last Post: 09-27-2015, 12:01 AM
  4. 29" Slack HT vs 27.5" Slack HT
    By c5marine in forum 29er Bikes
    Last Post: 09-03-2013, 08:31 PM
  5. When is slack too slack?
    By Lickqid in forum Downhill - Freeride
    Last Post: 10-30-2006, 11:10 PM
Members who have read this thread: 62
