73mm BSA w/ Boost Rear Hub- Mtbr.com
Results 1 to 3 of 3
    BrassBalled DropbarNinja
    Reputation: mrpercussive's Avatar
    Got a new frame and it's a 73mm BSA and Boost rear. If I run a regular set of cranks say Shimano XT for regular 73mm BSA, chainline should be alright with Boost? I'm not too familiar with all these new standards. Just know that when I was running 12X150mm on DH bikes i'd run an 83mm BSA... Can anyone confirm? Thanks!
    Reputation: dRjOn's Avatar
    if it (the chainring) clears it will be better than alright.... the non boost front ring chain line is improved if the casette is relatively further out. (by design it favours the chain sitting more towards the smaller cogs).
    the problem would only be if the chainring does not clear the chain stay or a swing arm...which seems to be generally unlikely to happen, unless you run bigger than average (32?) tooth rings.
    For a rock steady Gas Tank bag > the DeWidget
    bit.ly/BuyDeWidget
    https://www.instagram.com/drj0n_bagworks/
    Quote Originally Posted by dRjOn View Post
    Sick! Thanks!!!
  1. Cannondale SI or SISL2 Crankset on 73mm BSA Bike
    By sazaks in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-05-2019, 07:10 AM
  2. Replies: 80
    Last Post: 10-30-2018, 02:32 PM
  3. What BB for a PF30 X0 Carbon 73mm Crank on a 73mm threaded frame?
    By Imho4ep in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-12-2018, 03:15 PM
  4. 2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?
    By bwj75 in forum Shocks and Suspension
    Last Post: 11-09-2017, 02:21 PM
  5. Boost crankset with non boost rear hub?
    By 2AllBeef in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-19-2017, 03:14 PM
Members who have read this thread: 16
