2 Droppers : Too Stiff / Too Loose- Mtbr.com
Results 1 to 8 of 8
    Oct 2017
    This should be obvious, but for some reason I can't fix it...
    I have 2 bikes one with a BrandX 150mm dropper, the other a BrandX 120mm (internal). Both work perfectly fine. I swapped the posts over because the M-size bike needed the larger drop.
    Anyway, The result is the lever on the bike that now has the 150mm is really stiff to push. The function is fine, but you need to press hard & its annoying. I actually replaced the inner cable completely & set it up from scratch, but it's still the same.
    The other bike, now with a 120 dropper, has the opposite problem, the lever is super easy to press. This isn't actually a big deal being extra easy, but what is the solution here?
    Before swapping the posts, both bikes had normal lever pressure to operate.
    I would have thought it was just cable tension, but it doesnt seem to be, nor is it clamped too tight ... what might I have done wrong?
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    The remotes, are they the same, or different designs? Brand-x has a new remote design on the new droppers, if you have different remotes, maybe one is has the older design.
    Oct 2017
    They are the same design. Inside the seatpost has the cable end with anchor. The levers have a barrel connector with grub screw.
    No Clue Crew
    Apr 2005
    Routing of the housing?
    Just like a raindrop, I was born to fall.
    Oct 2017
    Quote Originally Posted by Blatant View Post
    hmm, good point to check. The hose was pulled out a bit since the post goes lower. Ill return it to previous position & see if it helps, perhaps there is a weird kink.
    Oct 2017
    Still cant work this out. I swapped the posts back to their original bikes & both work fine again, not stiff.
    Aug 2019
    Hardtail bike? And nothing is interfering with the cable like a water bottle bolt or the nut inside the seat tube?
    Oct 2017
    I think it must be cable routing as Blatant said. There is excess cabling between the lever & the frame entry, so it curls around & back. This probably creates more friction.
    When I pull the dropper post 90% out, & the cable becomes straighter, it seems to be easier. I guess I just need to trim it down.
    Not sure why the 120mm does the opposite & becomes super loose.
    The stiff one is hardtail, the loose one is FS.
  1. Chain Droppers
    By pcire in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-21-2011, 06:16 PM
  2. Stiff coil spring or stiff compression damping?
    By beanfink in forum Shocks and Suspension
    Last Post: 07-12-2008, 08:55 PM
  3. Where to get stiff or x-stiff coil spings?
    By Jtodd in forum Clydesdales/Tall Riders
    Last Post: 06-15-2008, 09:26 PM
  4. what should a fork be like: stiff or loose?
    By laxking77 in forum Shocks and Suspension
    Last Post: 12-16-2007, 04:40 PM
  5. fork springs...stiff or not so stiff.
    By doubleA's in forum Downhill - Freeride
    Last Post: 07-06-2004, 11:53 PM
Members who have read this thread: 59
