1990's Stumpjumper 26mm Threadless Stem Replacement- Mtbr.com
    Hi everyone. I'm replacing a 1990's Stumpjumper threadless stem, with a shorter stem from Velo Orange. I measured the old handlebar diameter and old stem as 1 inch, however, I accidentally ordered a 26mm not a 25.4mm stem. After realizing this, I ordered shims to go from 25.4 to 26mm. I installed the stem without the shims and it seems to fit the bar tightly. Should I still use the shims?
    This is the first time I've swapped out a stem, so I'm seeking some advise. I kept the handlebars the same, which are marked Specialized and look to be original to the bike. The stem that I am replacing is a longer vintage looker Tioga. Thanks in advance!
    1990's Stumpjumper 26mm Threadless Stem Replacement-cymera_20190511_070346.jpg1990's Stumpjumper 26mm Threadless Stem Replacement-cymera_20190511_070405.jpg
    You'll be fine. I have used road stems, which are 26.0, on several occasions in the past and on a current bike for years.
    EXODUX Jeff
    Thanks for sharing your experience!
    Another question. Is it possible the old stem covered more at the base of the headset? I know I ordered the right diameter stem to fit the steerer tube, but there appears to be more of a grease ring visible at the top of the headset. See photo, with pencil pointing to ring in question. If so, is there a part that will cover this area better?1990's Stumpjumper 26mm Threadless Stem Replacement-cymera_20190511_124139.jpg
  1. Talas service question: when 26mm ≠ 26mm
    By theycallmeE in forum Shocks and Suspension
    Last Post: 10-29-2015, 11:16 AM
  2. Stem adapter - quill to threadless stem
    By djork in forum Vintage, Retro, Classic
    Last Post: 10-05-2011, 12:04 PM
  3. Where to buy monstercross stem 40* rise (26mm)
    By Erik_A in forum 29er Bikes
    Last Post: 09-14-2008, 06:30 PM
  4. 1" threadless stem needed: circa 1990
    By First Flight in forum Vintage, Retro, Classic
    Last Post: 05-07-2008, 07:46 PM
  5. threadless to threaded to threadless Y Not?
    By Sasquatchcycles in forum Vintage, Retro, Classic
    Last Post: 11-23-2007, 10:44 AM
