1 inch (25.4mm) wide stems?- Mtbr.com
Results 1 to 7 of 7
    Oct 2018
    so i need to replace the stem on my rei drt 1.1, i cracked it on a jump.
    i'm looking for something on the cheaper side on amazon, but i can't find anything smaller than 28.6mm or 32mm.
    thanks!
    edit: the steerer tube diameter not bars!
    Cycologist
    Reputation: chazpat's Avatar
    I really doubt you have a 1" steer tube, it's 1-1/8". I think the mms you are quoting are the clamp for the bar, not the steer tube.
    This post is a natural product. Variances in spelling & grammar should be appreciated as part of its character & beauty.
    Reputation: fredcook's Avatar
    Don't go too cheap with stems on Amazon... they crack...
    You didn't quit riding because you're old, you're old because you quit riding.
    since 4/10/2009
    Reputation: Harold's Avatar
    If you've already broken an OEM stem on a jump, you need something BETTER quality than OEM.
    Or you're going to break it again.
    And yeah, that bike needs something for a 1 1/8" steerer.
    https://www.rei.com/product/106331/c...es-drt-11-bike
    Further, what sort of jump were you riding when you broke the stem? This bike isn't built for getting much air. It's just an entry level hardtail.
    Oct 2018
    Quote Originally Posted by Harold View Post
    it wasn't an OEM stem, it'd been a friends carbon stem that he gave me for my birthday, the way i cracked it is from doing a jump that was new, and the landing wasn't groomed, jumped, up,up up... then crack when i hit nose heavy on the ground, had suspension at max resistance so it didn't do much.
    Oct 2018
    i measured the steerer tube and not the stem.
    mbtr member
    Reputation: scottzg's Avatar
    1" steer tubes disappeared around the time suspension forks appeared. You need a stem for a tapered fork and a 31.8 handlebar. Super common.
    Props for sending it on a beginner bike.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
  1. Would 2.4 inch wide tires fit a 2.1 inch rim?
    By maximusaxe in forum Wheels and Tires
    Last Post: 01-30-2018, 06:01 PM
  2. Replies: 2
    Last Post: 03-11-2012, 09:39 AM
  3. 25.4mm seatposts?
    By hardtailkid in forum Urban/DJ/Park
    Last Post: 01-07-2011, 11:03 PM
  4. Replies: 14
    Last Post: 01-07-2011, 04:17 AM
  5. strong 25.4mm bar options, and 31.8 vs. 25.4
    By Lickqid in forum Downhill - Freeride
    Last Post: 12-19-2006, 07:21 PM
Members who have read this thread: 28
