Worth commuting another day?- Mtbr.com
Results 1 to 7 of 7
    So my bike rode fine to work this morning. After work though, I saw my back tire completely deflated. Well, I brought it home and took off the tire and found the hole on the inside. A piece of the rim strip was sticking out (old) and put a gash in the tube. I cut the sharp part off, and put some cushion over what was left (nothing sharp, just being cautious). I then patched the tube (about a 4mm long hole) and put it back on the bike. It seems to be holding air. Is it worth riding the 3.5 miles to work, maybe carrying a patch kit and inflater, or should I just drive and not chance it, and get new tubes and rim strips tomorrow?
    Which way? Uphill.
    Reputation: nepbug's Avatar
    Sep 2004
    Sounds like your set for the ride tomorrow.
    Always carry a tube and inflation when commuting.
    Blog
    Just keep spinning. Just keep running. Just keep paddling.
    Just keep moving forward.
    I'm SUCH a square....
    Reputation: bigpedaler's Avatar
    Ride.
    You have just experienced life with a bicycle. It is a flat tire, not a brain tumor.
    JEEZ!!
    A bike is the only drug with no bad side effects....
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Flat tires happen. Usually they don't happen all the time.
    Right now, I am not carrying pump, tube or patches. If I have a flat, I'll walk the bike home: takes about an hour.
    MTB Addict
    Anywhere I go, my bike has a spare tube, tire gauge, multi-tool and mini-pump on it. Fortunately, I don't get flats much, but I'm always ready if I do.
    Reputation: wheelbender6's Avatar
    Once you are prepared for something, like a roadside flat or broken chain, it tends to happen less often.
    "I don't suffer from insanity!I rather enjoy it."
    Reputation: Joules's Avatar
    ride, worst that can happen: you flat at the exact midpoint and have to walk 1.75 miles. A half hour walk will not kill you.
    I rarely get on a bike without stuff to fix a flat, and always keep at least 2-3 spare tubes in the house. prevents these sort of issues.
