Wide Platform Pedals for Short Commute- Mtbr.com
Results 1 to 16 of 16
    I have a relatively short commute and don't bother changing clothes, so I just ride with my work shoes, which are either rubber-soled loafers or leather-soled oxfords. I'm looking for a wide platform pedal that these shoes won't slip off of. I don't want to spend a lot, but I need an upgrade because I'm getting sick of sliding off my cheap cage pedals. Any suggestions?
    Sexy Mother Fakir
    Reputation: Electric Vindaloo's Avatar
    I have the DMR V12 pedals on my commuter but they're kinda spendy. Sounds like the DMR V8 pedals would probably work for you and only around $30. Mine have been going strong for almost five years now so I should probably service them soon. The screw-in traction studs are quite grippy.
    http://www.universalcycles.com/shopp...s.php?id=10856
    jfk
    jfk is offline
    Reputation: jfk's Avatar
    had the same problem, same solution. I picked up a pair of welgo down hill platforms. They're really heavy and have to watch your turns a little more because they will scrape easier. I found they are worth it. I also have removable studs, they work great with sneakers, with some thin dress shoes I can feel the studs. My feet do stay on the pedals and after about 500 miles or so I still haven't "bear trapped" my shin yet.
    I just kept looking online until I found a pair at decent price, retail they are all very expensive ($60+ with $100 being a good midpoint), I think I eventually got a pair on clearance from REI for about $35. If you need it now, Universal Cycles carries a lot of different types / brands, at least you can get a feel for whats out there.
    Wellgo makes inexpensive, well-rated, platform pedals. In particular, the MG-1s are supposed to be excellent, but they will run you ~$60.
    Expensive Mistake
    Quote Originally Posted by tsmosher
    +1
    You can get MG-1s on ebay for under $40. I've bought 2 pairs from a seller called "abaxo".
    http://cgi.ebay.com/WELLGO-MG-1-MG1-...9#ht_662wt_911
    2009 Kona Kahuna 29er
    2010 Dawes Deadeye
    ride the moment
    Reputation: Dogbrain's Avatar
    The Redline Alloy SB (sealed bearing) platforms are $40 msrp. I've been commuting on a pair in Oregon (very wet) for 2.5 years and they still feel great. Grip is awesome. I ride them in cowboy boots pretty regularly.
    Hey Butthead, are we gonna die? - Beavis
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    Quote Originally Posted by Dogbrain
    ... I ride them in cowboy boots pretty regularly.
    Pic please
    Jun 2010
    I've been using these Primo pedals on my Jamis since 2003.
    http://www.modernbike.com/itemgroup.asp?IGPK=-715532185
    09 Jamis XCT2 Marzocchi RC3 ti forks, XT/XTR drivetrain, Mavic Crossrides/ Kenda Nevegal DTC=29lbs
    No-Brakes Cougar
    Reputation: Gary the No-Trash Cougar's Avatar
    I have the Wellgo BMX pedals as well, albeit with non-removable studs. I've been using them daily for a couple of years now and haven't had any problems with the studs wearing down. Unless you're riding BMX and grinding your pedals on coping it's not going to be much opf an issue, plus they're are much cheaper.
    R.I.P. Ronnie James Dio ~ July 10, 1942 May 16, 2010
    I got nothin'
    Reputation: hydrogeek's Avatar
    Feb 2006
    I'm picturing Lycra shorts with these boots.....
    I ride at ludicrous speed
    I use Wellgo LU-214. For $16, can't complain and works well.
    http://www.rei.com/product/752213
    master blaster
    Reputation: veloreality's Avatar
    mks grip kings kick ass
    on the left
    <img src="https://www.rivbike.com/images/products/full/0000/1617/tourlite.jpg">
    i like MKS Touring pedals, they're really wide. I ride with workboots alot and have plenty of room. also have wellgo platforms on my other bike and they're just as good, probably a little stickier, but a little heavier
    smell the saddle...
    Reputation: stumonky's Avatar
    I use the Wellgo LU-961 clips w/o the straps. Any shoe slips under easy and almost feels like clipless without the cleats. Very easy to get in and out of too. You can search around and get them for under $20.
    ride the moment
    Quote Originally Posted by mtbxplorer
    Pic please
    Quote Originally Posted by hydrogeek
    I'll snap a pick this evening, but you'll be disappointed at the lack of lycra. I really like boots and have a couple pairs depending on the occasion. I cruise around town on my 700c with mustache bars wearing jeans and boots. Point is that leather soles stick fine to the pedals.
    Odessy JMC. Best pedal ever.
