Who makes this commuter?- Mtbr.com
Results 1 to 12 of 12
    Looking for a commuter with the following attributes:
    steel frame
    700c wheels
    1 x 8/9 drivetrain (non-gripshift)
    cant brakes
    upright bars
    fender and rack mounts
    will accept 35-38 mm tire width
    Found a few things that are close, but no exact matches.
    Any suggestions?
    Bedwards Of The West
    Oct 2007
    I'd say pick a frame and build it up yourself... seems like lots of frames would fit these criteria.
    (no excuse for that either)
    Reputation: dbhammercycle's Avatar
    Quote Originally Posted by Zirkel View Post
    Sounds like you have bike builder's disease and the only way to cure it is to... build your own to your own specifications.
    Perhaps the Pake C'mute? or Surly Trucker or Crosscheck?
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    z1r
    z1r is offline
    Apr 2014
    Quote Originally Posted by CommuterBoy View Post
    that would be my recommendation too. I like the New Albion privateer for this. Mine is a svelte 22 lbs as a 1x10 or single speed.
    That said, this a great deal that ticks off al the OP's boxes except for canti brakes and bars but is cheap enough that swapping to straight bars would be cost effective:
    Charge Plug Sora - 2015 - Performance Exclusive
    Reputation: rogbie's Avatar
    A 90s Trek 700 series Multitrack or Metrotrack is exactly what you need.
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    Excuse me for asking, but why wouldn't a commuter want disc brakes?
    Rivendell still uses canti brakes. As well any older mt bike or hybrid. Used, older Surly? Most anything new these days will have disc mounts. My choice? Get an older road bike frame that took 27" wheels, should fit the bill. The 700 wheels are slightly smaller. Might need longer reach brakes, esp in the front.
    Quote Originally Posted by mtbxplorer View Post
    I think this depends on your area. If you live in a temperate area with not a lot of moisture, rim brakes are just fine.
    Me personally, disc is where it's at.
    Oct 2007
    Exactly. Ask Rodar this question. I can't figure it out.
    B/c a rim brake is a disc brake. A really big disc brake.
    Oct 2007
    Quote Originally Posted by rogbie View Post
    here we go...
    I'm not biting... it's just too easy of an argument
    The Privateer is looking like a winner. Just spoke with the guys at American Cyclery in SF about building a 1 x 11 Privateer with cantis. They might be able to work within my budget. Thanks for all the input.
  1. Replies: 29
    Last Post: 11-18-2014, 02:31 PM
  2. New bike commuter, needs advice on new commuter bike.
    By Rustedthrough in forum Commuting
    Last Post: 08-26-2014, 10:34 AM
  3. How come nobody makes a....
    By Stumpjumper61 in forum 29er Components
    Last Post: 04-02-2013, 06:21 PM
  4. Well... we'll see if he makes it!
    By wsmac in forum Downhill - Freeride
    Last Post: 12-21-2012, 06:42 PM
  5. QBP makes right
    By Harold in forum General Discussion
    Last Post: 10-15-2011, 08:35 AM
