When is someone going to test LITELOK?- Mtbr.com
Results 1 to 5 of 5
    Mar 2016
    I would like to see the following test done in this order.
    Attempt to break the lock with.
    1) High quality grinding disc.
    2) Sharp, blade aligned bolt cutters.
    3) Sharp, blade aligned hydraulic bolt cutters.
    4) A properly used acetylene cutting torch.
    Time all methods and try them on both the band and buckle.
    I would do it, but have no money for all this crap.
    Reputation: BrianMc's Avatar
    Well if you googled, you'd have found this:
    https://www.youtube.com/watch?v=KB2ghne7sOU
    No hydraulic bolt cutters, and a portable propane torch and they did not try the buckle with the hacksaw (which appeared to loose its teeth) or the angle grinder.
    Maybe you can find those.
    Mar 2016
    If that link is to the litelok video on youtube, I have seen it. I was wanting something a bit more thorough.
    ~ B A D A S S ~
    Reputation: car bone's Avatar
    Quote Originally Posted by lighty View Post
    this is shit lock for sure. they are not even trying in the vids. Give me that angle grinder and i will have it open in less than 10 seconds.
    Or that bolt cutter and i will have it open in like 5 seconds. this is just like the tigr lock. complete BS. if you want something good get a pragmasis. done.
    plz send me all locks for testing and I will destructively test them in a real life scenario. and no locks will survive for more than 30 seconds.
    I can guaratee you that.
    Rule #9 // If you are out riding in bad weather, it means you are a badass. Period.
    Quote Originally Posted by iheartbicycles View Post
    Specialized sucks ass.
    Mar 2016
    Maybe you should ask litelok for one.
  1. Test Test One Two Three
    By Mr. Ryan in forum test forum
    Last Post: 12-14-2013, 01:25 PM
  2. Test
    By Rumrnr in forum test forum
    Last Post: 12-08-2013, 09:04 AM
  3. Test
    By tajar66 in forum test forum
    Last Post: 10-05-2013, 07:04 AM
  4. test test
    By fc in forum The ReCycle Bin
    Last Post: 02-18-2012, 10:31 AM
  5. pliny test beer taste test
    Last Post: 06-26-2011, 01:22 PM
