What's a good 29" commuting tire?- Mtbr.com
Results 1 to 14 of 14
    Jun 2012
    What's a good tire for commuting that is made in the 29 inch size.
    I'm having a really hard time finding many options.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    any 700c tire should work. I have used Schwalbe marathons and they work great
    Jun 2012
    wow, 700C they actually fit on the rim of a 29er? I thought 29 inch was the whole diameter of the wheel with the tire, which would seem to make the rim a bit smaller diameter than a 700c, since the 700c use significantly smaller tires than mtb.
    that's great to know. should any 700c fit, or is it like just certain models?
    the 29er rim size is 700c or 622 mm ISO. So any tire should fit (just don't try ultranarrow road tires on a very wide rim )
    Bedwards Of The West
    Oct 2007
    29" is the estimated diameter of an average mountain bike sized tire on a 700c rim. Any 700c tire will fit, but "29er" rims are generally wider than road rims, so you don't want to go TOO skinny, or you'll get a funny shape/rim edge sort of sitting out there waiting to be scratched up.
    I have gone down to 700x35 on my WTB Speed Disc wheels with no issues.
    As for tires... I've had very good luck with Schwalbe Kojacks in 700x38, Schwalbe Big Apples in 29x2.35, and Just getting started with Serfas Drifters in 29x2.0...like them a lot.
    Schwalbe and a few other companies label their 29er tires "28"... my Big Apples were labeled 28x2.35...this is just a more accurate way to say 29, really, since it's the inner diameter of the tire they should be measuring anwyay... in reality it's 700c, but they know Americans are afraid of the metric system, so they try to get it as close as they can in inches... so 28 means 29, and 700c means 29
    (no excuse for that either)
    Jun 2012
    thanks a lot! I sure am glad to hear that. That sure expands my options. thanks guys!
    Reputation: junior1210's Avatar
    I've had great results from Kenda Kouriers 35mm and 40mm tires, just switched to 2.3 inch Origin8 Captiv8ers, that are working well. Duro, Continental, and Michelin also make decent tires. It's more about what you want to spend since there are good tires at most price points.
    The ridiculousness of cycling clothes increase exponentially in relation to the distance from your bicycle.
    Reputation: sanjuro's Avatar
    Sep 2004
    Schwalbe Marathon Supreme.
    It ain't cheap but there is nothing better. I and a friend who commutes 5x miles I do on his 29er both swear by it.
    since 4/10/2009
    Reputation: Harold's Avatar
    I am using CST Crucibles on mine. 700x32 size. So far, the tread has been deep enough to avoid punctures on all the road debris I have to deal with on a daily basis, and they maintain sufficient traction in what limited wet I've had so far. On Velocity Dyad rims, which aren't quite as wide as most mtb rims, but a little wider than most road rims (they're labeled for tandems and trekking bikes and such, and made for wider road tires).
    Digital Toast
    Reputation: Zeroack's Avatar
    I'm running these....
    I got a killer deal on the pair and couldn't pass it up. They roll very well with that nice centerline in the tread.
    Jun 2012
    nice. I'm going to try the Continental Contact Extralight Reflex City Tire. See how that works for me.
    Quote Originally Posted by Zeroack View Post
    Thats' a WTB Nanoraptor for those who can't recognise a tyre by its tread alone :-)
    M8 M12 M15 deez nuts
    LOL I have those on my XC race bike. Not the greatest of confidence in off-camber/loose/sandy corners at speed!!! I suppose theyíd be great commuter tires though, seeing as yes they do roll fast and donít weigh much at all. I recommend running them tubeless (with Stanís anti-flat goop) so as to avoid pinchflats entirely.
    Donít frail and blow if youíre going to Braille and Flow.
    Sloth Hunter
    Reputation: BooBoo's Avatar
    May 2005
    Schwalbe Big Apples 2.35 are awesome for 29er urban assault riding.
Members who have read this thread: 4
