Using my MTB for comute to work- Mtbr.com
Results 1 to 24 of 24
    Apr 2019
    New question here. Using my MTB for comute to work
    Hi all,
    I have a Specialized Rock hopper MTB and would like to start commuting to work. The Journey is 13 miles mostly on the road.
    Would this bike be fine for this? What modifications could I add that are needed?
    Any advice is welcome.
    Reputation: felipespinoz's Avatar
    Apr 2017
    Get the bike as light as possible
    get new skinny soft rubbers
    If not steep, go SS
    Get a good basket or mounting hardware for your stuff
    Good Lights White front red rear
    Reflective accesories and/or clothing
    And be aware of cars!
    Good rides!
    Enviado desde mi MotoG3 mediante Tapatalk
    Check the tires for the maximum psi and pump them up to that. When they wear out get skinnier ties you can inflate to a higher pressure.
    You may want a more upright riding position. Hit up the service guys at a local shop for a used stem that is a little shorter with some rise still. Should be only a few bucks.
    Check your chain for lube and wear.
    Check the teeth on the front chain rings and rear cassette for wear.
    since 4/10/2009
    Reputation: Harold's Avatar
    No modifications are NEEDED at this point that we can tell.
    pavement-friendly tires would go a significant way towards making the bike feel quicker.
    Make sure the bike is in good working order and is well lubricated and ready to go.
    13 miles on pavement is enough that if your fit isn't dialed for that bike, you'll probably start to feel it. At this point, it's impossible to make recommendations, and even then, making fit adjustment recommendations online is pretty futile.
    Low profile tires will make it easier, and something with puncture protection is ideal. I preferred a rack+panniers but I didn't have a proper shower there so I needed to avoid sweat.
    Get a rear Blinky (or two!) And a decent front light once winter rolls around.
    Have fun!
    Sent from my Moto G (5) Plus using Tapatalk
    Quote Originally Posted by SpeedyTrails View Post
    Hi all,
    Nothing is NEEDED, but number one thing would be slicks. I actually prefer fatter slicks for our roads, had super narrow 26x1Ē slicks for a while, too punishing. 1.5 or even wider are much more comfy and still fast. Flat resistance is good. I need to find me some tubes that i can run sealant in as another line of defense, getting a flat on commute is a pain, and the tires i have now are incredibly tight on the rims. Make sure you have everything to deal with a flat.
    After that make sure riding position is dialed, commuting/road youbtend to stay seated all the time. Shorter higher rise gets you more upright for visibility but shifts weight to the saddle.
    Lights to be seen, i run a headlight even during the day. And wear the most eye searing shirt ive got.
    When you get more serious, fender ls make a big difference in keeping you less dirty. If you need to carry stuff, i prefer panniers to carry load on bike.
    slow
    Reputation: sgltrak's Avatar
    Feb 2005
    When I was commuting on my MTB, I still used it for weekend rides and a week night ride, so I built a second set of wheels as my dedicated commute wheels. The had light, fast, puncture resistant tires and a higher gear range. If you are in the same boat, you should be able to find a great deal on a good 26" wheelset.
    Reputation: Mr Pig's Avatar
    Buy good puncture resistant tyres.
    Reputation: Wacha Wacha Wacha's Avatar
    Sep 2017
    As previously noted, my two recommendations are lights for front and rear and fendors. Have fun!
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    needed ? required ? a daylight visible tail light, such as niterider sentry aero 260
    seriously, get a bright tail light and use it all the time you are on pavement
    for the bike, just air it up and ride it
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Apr 2019
    Thanks for all the advice guys.
    So far i've put front/rear fenders and lights. Now looking into some slick tyres.
    Super Moderator SuperModerator
    Reputation: driver bob's Avatar
    Once you've got the tires its job done. Then time to get out and ride it!
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    Hi all,
    My advice on top of all the others is to not go crazy with pressure in the tires. It will feel really fast once you put some slick tires on it but it is also a stiff aluminum frame. Rode riding is a lot of small frequency vibration with some bigger hits thrown in but unlike mountain biking you tend to spend most of you time in the saddle. Finding a happy medium where the tires aren't floppy feeling but are supple and can absorb a lot of the small frequency stuff will greatly increase your comfort. Often my tires leak down on my bike and I find there is a really nice zone where i am so happy for a week but then the next week I start to feel a little sidewall flex in the corners and stop feeling the expansion joints and when I check my pressure it is usually down 15psi from where i started.
    I also found that getting panniers and a rack is a nice addition and i use them twice a week. Once on Monday to bring in my weeks clothes and a clean towel and once on friday to bring everything back home. Then the other 3 days I can ride with a light pack or my handlebar bag with just my lunch.
    MTBR Posting Guidelines
    calories>electrons
    Apr 2019
    Tyres ordered, I went with the Specialized nimbus 2 In 26" 1.5. Thanks for replies.
    Looking at shorter stems but undecided on the size.
    Which ones? The puncture protection on the Sport isn't anything special. The protection on Armadillo, is!
    Apr 2019
    I went with the Nimbus 2 all road tyre. It doesn't say Armadillo so I'm guessing they are the sport version. They have flak jacket protection so I will see how long they last. They do get a good review so we will see.
    Flack Jacket sits in between Sport and Armadillo and is really good. In practice, I can't see and difference between Flack Jacket and Armadillo. Neither of them are very likely to puncture, ever. You can ride these tyres over broken bottles and they won't flat. Very solid choice.
    NDD
    NDD is offline
    Reputation: NDD's Avatar
    Jul 2013
    Quote Originally Posted by Mr Pig View Post
    You ride over a lot of broken bottles over there, eh?
    I think that bike looks pretty good, SpeedyTrails. Have you started commuting yet?
    dang
    Cycologist
    Reputation: chazpat's Avatar
    Add a bottle cage and water bottle, unless you are using a Camelbak or similar.
    This post is a natural product. Variances in spelling & grammar should be appreciated as part of its character & beauty.
    Have done. The cycle path next to my house runs past villages where the local cherubs enjoy nothing more than drinking cheap wine and smashing bottles.
    NDD
    NDD is offline
    Jul 2013
    Oof. I ride through an industrial area and by a number of bars on my commute but haven't really had this, fortunately. No worse reason to shred a nice tire than that some redneck/ned/bogan (did I cover the important ones) just wanted to be a moron.
    Sent from my LM-X212(G) using Tapatalk
    dang
    No worse reason to shred a nice tire than that some redneck/ned/bogan just wanted to be a moron.
    Yeah, but my point is that the Nimbus Armadillo can take it.
    Apr 2019
    Iíve been commuting to work for the last couple of weeks. At first it was tough but itís getting easier. The tyres are great and feel solid.
    Iíve added two water cages, pannier rack, mud guards front/back and white/red lights.
    Reputation: jbadger1977's Avatar
    Jan 2015
    That's awesome. Keep it up and it should keep getting easier!
  1. Replies: 0
    Last Post: 04-07-2015, 01:59 PM
  2. For guys using headphones while riding - anyone using bluetooth?
    By swing22hard in forum General Discussion
    Last Post: 03-11-2014, 06:45 PM
  3. Good work-out for my 1.5 hour after work ride.
    By y0bailey in forum XC Racing and Training
    Last Post: 07-21-2011, 01:12 PM
  4. Using a Shimano Tiagra front mech on my MTB?
    By phazer in forum Weight Weenies
    Last Post: 01-06-2006, 01:16 PM
