• 01-26-2015
    jl
    UltraFire Cree--good light for the commute
    I received an Ultrafire CREE XM-L T6 and thought I would provide an evaluation. This is a nice compact flashlight with a really visible light that is zoomable. This probably is a miliitary spec type of build but for $10 dollars this is a hard to beat flashlight. It does in my opinion have some drawbacks but for the money it is a good deal.
    Ultrafire CREE XM-L T6 2000LM 3 Modes Zoomable White Flashlight Gun Color - Tmart
    Pros: The casing for the flashlight is solid and well done. I like the fact that you can use an 18650, or 3-AAAs to use the flashlight. There is an adapter for both types of batteries. I have a supply of 18650s so that is what Iíve been using with this light. The LED and the driver seem to be solid with no problems. The zooming of the light was smooth and really simple. The ring runs on a small ball-bearing and was greased nicely.
    Cons: The threads on this light are not as clean as I would of liked. It is gritty opening and closing the flashlight. Also there seems to be some debris (maybe from the manufacturing process) in the tailcap. Also the lens was slightly chipped on the edge. The switch didnít feel as solid as I would like it to be. Iím not sure how long it will hold up, works great. I just like a more substantial switch.
    Opinions: My own personal complaint is that you have to cycle through all the modes to get to a different mode or shut off the flashlight. The other light I have allows you to turn off the light and turn it back on and remain on the same setting, or half-depress the switch to change modes. With the UltraFire, you have to click through all the modes to get to to shut it off or loop again if you missed the mode you want. I would also like a way to toggle between the strobe modes. My current light allows you to be in a 3-mode (no strobes) setting or a 5-mode setting (strobes).
    With the Ultrafire, I wish the medium setting was a little dimmer. There was much less difference between the medium and high settings than the low and medium settings. My last personal opinion is that the light is more blue than I normally like, but different people like different spectrums.
    This could also be a great commuter light. It is bigger than my convoy but smaller and a better light (lot less spotty) than the TangsFire I was using last year.
    Because this is light has the ability to support AAAs, it becomes a good candidate for giving as a gift. None of my friends or family are using 18650s as batteries for flashlights.
    Below are picture comparing this light to a convoy light that I built myself. Keep in mind the host was $15 and I had to purchase the driver and the emitter separately. So we are comparing a $25-$30 dollar light with a $10 dollar light.
    Hereís a long list of pics to show comparisons.
    UltraFire Low Beam: Zoomed to Unzoomed
    <img src="https://lh3.googleusercontent.com/-eIy4p4El_MM/VMaqufiIvoI/AAAAAAAADYU/K3kklgUr9_0/w968-h726-no/IMG_0254." width="80%"/>
    <img src="https://lh4.googleusercontent.com/-XxcMuomZogY/VMaquwyr8JI/AAAAAAAADYY/dHE6xwo-B-E/w968-h726-no/IMG_0257." width="80%"/>
    <img src="https://lh6.googleusercontent.com/-_8tsRkrwxRQ/VMaqvjOeYLI/AAAAAAAADYg/hXIAYxvyb8U/w968-h726-no/IMG_0260." width="80%"/>
    Convoy Low Beam:
    <img src="https://lh3.googleusercontent.com/-iy0nXYUuZzg/VMaqpoSzHFI/AAAAAAAADXM/G1yb3QO4SzI/w968-h726-no/IMG_0228." width="80%"/>
    UltraFire Medium Beam: Zoomed to Unzoomed
    <img src="https://lh5.googleusercontent.com/-xpGv8BWrly4/VMaqs6ZgTUI/AAAAAAAADX8/yRaWRri8RgU/w968-h726-no/IMG_0245." width="80%"/>
    <img src="https://lh5.googleusercontent.com/-fiSOUgZaPS8/VMaqtUtyfeI/AAAAAAAADYA/3m9bIg6C_T0/w968-h726-no/IMG_0248." width="80%"/>
    <img src="https://lh6.googleusercontent.com/-Yq7Do8aRlLY/VMaqtyZVLnI/AAAAAAAADYM/tVTFWHvaDuo/w968-h726-no/IMG_0251." width="80%"/>
    Convoy Medium Beam:
    <img src="https://lh5.googleusercontent.com/-5Z6Jx4lMGcs/VMaqqUnGZgI/AAAAAAAADXU/y-lXPEqJryU/w968-h726-no/IMG_0230." width="80%"/>
    <img src="https://lh4.googleusercontent.com/-4Hgaw-c1J5E/VMaqr3_fsuI/AAAAAAAADXs/02Xu9Ee7azY/w968-h726-no/IMG_0239." width="80%"/>
    <img src="https://lh3.googleusercontent.com/-1jnhvdntyWQ/VMaqsQrIi4I/AAAAAAAADX0/eE7si_SZ20k/w968-h726-no/IMG_0241." width="80%"/>
    <img src="https://lh4.googleusercontent.com/-AILQiCJwJcU/VMaqreGhM4I/AAAAAAAADXg/7kADXDZFc1g/w968-h726-no/IMG_0236." width="80%"/>
    Convoy High Beam:
    <img src="https://lh4.googleusercontent.com/-ANmUuZ4tpsY/VMaqqxOP7NI/AAAAAAAADXc/1LXabUCWcv4/w968-h726-no/IMG_0233." width="80%"/>
    Side by side shot low-medium-high:
    <img src="https://lh3.googleusercontent.com/-2rQ1kuApC88/VMaqwUDww8I/AAAAAAAADYs/zuv2hFA55u4/w968-h726-no/IMG_0263." width="80%"/>
    <img src="https://lh6.googleusercontent.com/-lJRPHZ1pD5I/VMaqwx697GI/AAAAAAAADYw/2d48i00aCuU/w968-h726-no/IMG_0266." width="80%"/>
    <img src="https://lh3.googleusercontent.com/-2-qMirtZa9g/VMaqxapMGPI/AAAAAAAADY8/VrjBK6kEZxY/w968-h726-no/IMG_0269." width="80%"/>
    Random Build Shots:
    <img src="https://lh5.googleusercontent.com/-hx_sF0-NeR8/VMaqxz74INI/AAAAAAAADZE/nxclcRmVG88/w968-h726-no/IMG_0275." width="80%"/>
    <img src="https://lh6.googleusercontent.com/-7Lf95wYA6cA/VMaqyaOPn9I/AAAAAAAADZM/ZgS7TEXkyOE/w968-h726-no/IMG_0276." width="80%"/>
    <img src="https://lh6.googleusercontent.com/-x9E8RyDBMRY/VMaq043Z1RI/AAAAAAAADZ0/xShsUwcF-kw/w968-h726-no/IMG_0283." width="80%"/>
    <img src="https://lh4.googleusercontent.com/-UUqvwkeGpfI/VMaq1Ro9FeI/AAAAAAAADZ8/ALNinOEuIfE/w968-h726-no/IMG_0284." width="80%"/>
    <img src="https://lh4.googleusercontent.com/-xKGubh6_esA/VMaq1xOT8iI/AAAAAAAADaE/kQF_mifAap0/w968-h726-no/IMG_0287." width="80%"/>
    <img src="https://lh3.googleusercontent.com/-CjHBqIeV2BI/VMaq2CohIPI/AAAAAAAADaI/14mZ22K4lJ8/w968-h726-no/IMG_0288." width="80%"/>
  • 01-26-2015
    snailspace
    I too like the smallish flashlight concept, especially if they take AA or AAA batteries. This type of lighting is something I am researching at the moment. Some of the lights out their are pretty costly especially with their lithium batteries. Although with AAA`s I worry about battery life.
  • 01-27-2015
    jl
    This is one of the attributes I like about this flashlight is that it has a AAA adapter. They do have rechargeable AAAs these days, but as I stated, I've been using 18650s. I really like using a flashlight for commuting. I just have a simple 'elastic' handlebar attachment, and I can use the flashlight for many other applications.
  • 01-28-2015
    gumby.
    I've been using similar ones for a couple of years, the focused lens is a lot easier on other road users, on well lit streets I use it on the lowest setting. I don't know of any cons for this type and use these clips.
  • 02-01-2015
    vmps
    I hate high powered round beams on a bike for anything other than blinding oncoming traffic and lighting up the sky. For that, they are great. And I'm sure they make great flashlights.
  • 02-01-2015
    gumby.
    You've got the wrong end of the stick.
  • 02-01-2015
    BrianMc
    There is some truth (wide and medium beams aimed incorrectly) but also some inaccuracy in that statement:
    The lower pair of round lights on fork mount:
    Low beam (twin XMLs with narrow round lenses):
    The same on high with the (XP-E-& 2 XPG) helmet light for throw:
    I have tested these for glare and use snoots to control that:
