Tube vs. Patch
Printable View
  • 07-25-2011
    swell6
    Tube vs. Patch
    What do you guys do when you flat?
  • 07-25-2011
    jeffscott
    Geez I am off the bike and back on with a new tube in less than 5 mins.
  • 07-25-2011
    mtbxplorer
    I use a spare tube, and then patch & test later & then use as a spare.
    In the winter, if I'm already @ the bus route, I just put the bike on the bus and change the tube in the warmth of the office. Strangely, none of my flats have been on the way home, where this techinique would not work since my house is 3.5 mi from the closest bus stop.
  • 07-25-2011
    woodway
    Install new tube. Patch old tube and put back onto the bike. When a tube gets 4-5 patches on it, discard for a new tube.
  • 07-25-2011
    Dalton
    I always go new, but I want to start patching. Its just so much less work to buy a new one and make a strap or belt out of the old. :thumbsup:
  • 07-25-2011
    mtbxplorer
    ^^Think of it this way...if you patch a tube in 5 or 10 minutes instead of always buying a new tube for $5, it's like paying yourself $30-60/hr for the labor :thumbsup:
  • 07-26-2011
    oromis
    I have gotten to where i always throw in a new tube first. When i get home i will patch the tube but it must hold the same amount of air for 24 hours before it is deemed worthy to use again.
  • 07-26-2011
    AndrwSwitch
    Ditto.
    I have enough tubes kicking around that I generally wait until I have six punctured ones, then patch them all at once. It's like paying myself even more in an hour - it's a little more efficient than doing one at a time.
  • 08-01-2011
    Blind
    on my commute with my road bike, even with using continental ultra sport 27" tires, and pumped up to 110psi, I have been catching goathead thorns about twice a week.
    I'm pretty good at patching, but if I'm time crunched I just swap to the spare tube and patch when I get into work. I think all my tubes have 5-10 patches on them? Never had an issue with a leak after patching. Just have to use the nice glue patched with the orange rings around the patches, those are the ones that work the easiest for me.
  • 08-01-2011
    Nenbran
    I get too many flats to do anything other than patch all of my tubes as well as carry a spare. I think my rear tube has like 4 patches and it's running perfectly.
  • 08-01-2011
    Schmucker
    I don't get flats. Buy decent tires.
  • 08-01-2011
    Nenbran
    Originally Posted by Schmucker View Post
    Buy decent tires.
    Try living in the desert.
  • 08-02-2011
    spartacus001
    I rarely get flats on my rides. Secrete is Mr. Tuffy tube liners on all 3 of my bikes.
    But in that rare occassion I get a flat I change the tube and always patch the old one.
  • 08-03-2011
    Shalom
    New tube. The joys of working part-time in a bike store is that tubes are dirt cheap. Old tubes are used round the garden, tying things onto the truck, etc.
  • 09-03-2011
    cyclehorse
    tube - quicker!
    ... I used to try roadsite patch-ups but no more. It's all about speed and it's quicker to take the tube off and start over again.
  • 09-03-2011
    highdelll
    "Pay bike shop to install tube?"
    Anyone that does this does not deserve to own a bicycle :rolleyes:
  • 09-03-2011
    Fix the Spade
    I make a lot of money fixing punctures, so don't knock 'em :D
  • 09-03-2011
    highdelll
    That's good for you ;)
    but, anybody that has to take their bike into the shop for a flat is either: super pro elite rich that cannot be bothered with doing ANYTHING to their own bike OR a frikken moron.
    I suspect the latter is usually the case.
  • 09-03-2011
    jseko
    Then there are the mechanically inept. By trade I'm data systems engineer, I can build an entire virtualized server farm as long as the networking part isn't too complicated, but put me around something mechanical and I'm lost.
    Ok, I can change a tire and tube out ok, but try to get me to adjust a derailleur or my brakes and I'm lost if it involves more than the barrel adjuster. I can wipe down the chain with Simple Green every couple weeks and put Triflow on it, but that's about it.
  • 09-05-2011
    Khai
    On the road it's always a new tube - way faster. I'll patch a tube when I get home, but I don't want to be dealing with that crap on the side of the road unless I have to (I generally carry patches as well, but haven't had to use one roadside yet).
    Stans in the tube helps too. :)
