Tires- Mtbr.com
Results 1 to 5 of 5
Thread: Tires
    Commuta
    Tires
    I'm currently running Continental Contact 700 x 32c's on my Dr. Dew, but want to switch over to something faster.
    I'm considering Continental Contact Sports, which are 700 x 28c. Will I have to change the tubes in order for them to fit?
    Thanks !
    i also unicycle
    probably not, but maybe.
    mtbr says you should know: i work in a bike shop.
    bikes & beers (on my blog) http://idontrideenough.blogspot.com/
    weirdo
    Reputation: rodar y rodar's Avatar
    Tubes are usually designed for a given size range, which should be marked right on the tube. You can usually get away with stretching a tube in a bigger tire than it`s supposed to go with, but stuffing a big tube into a small tire can sometimes cause it to bunch up or get pinched between the rim and the tire bead. I had that problem when I tried to use 26x1 3/8 (Schwinn 26", which are actually quite a bit bigger diameter than mtb) in 26 x 1.5 slicks.
    Never trust a fart
    Reputation: frdfandc's Avatar
    It usually depends on the tubes themselves. The brand I use are available in a 28-32 size so they will fit both size tires.
    Commuta
    Thanks for all this info, this helps a lot.
