Tire Clearance- Mtbr.com
Results 1 to 8 of 8
Thread: Tire Clearance
    29er and 26er
    Mar 2012
    Tire Clearance
    I just purchased some Schwalbe Winter studded tires for my old road bike size 700cx30. How much clearance do I need between the tire and the brake caliper? I have about 2mm of clearance. Is that enough?
    Yup as long as it clears when the brakes are applied....snow doesn't pack up as bad as mud.
    Dec 2016
    yep that is enough space
    29er and 26er
    Mar 2012
    I only asked because someone told me that if by chance a small stone greater than the gap got caught in the tread it could stop the wheel and send me over the bars. Is this a possibility, or am I safe?
    Studs would not make a difference....and I have had tight clearance tires with no problems
    Ice buildup? Or wheel wobble? Should be fine. Got a cross frame for more room?
    Human Test Subject
    Reputation: Volsung's Avatar
    You may lose paint when your frame flexes. I learned that the hard way
    Quote Originally Posted by p08757 View Post
    You're safe. The stone will most likely just get pulled out of your tire tread. Worst case is the stone/shard/whatever will be forced into your tire resulting in a cut or flat.
  1. El Rey tire clearance
    By intheways in forum Ventana
    Last Post: 08-29-2014, 01:23 PM
  2. Anyone know what tire clearance is like
    By Harryonaspot in forum Pivot Cycles
    Last Post: 10-11-2012, 08:20 AM
  3. SB-66 & Tire Clearance
    By CharacterZero in forum Yeti
    Last Post: 10-09-2012, 05:30 AM
  4. Big Top Tire Clearance/Tire Choice
    By TheFCuddy in forum Yeti
    Last Post: 10-07-2011, 06:51 AM
  5. Replies: 2
    Last Post: 07-12-2011, 07:39 AM
