Thoughts on seatpost racks- Mtbr.com
Results 1 to 8 of 8
    Reputation: wunderkind's Avatar
    Anyone use them for their commute? Am wondering if there are some that are pannier friendly.
    No-Brakes Cougar
    Reputation: Gary the No-Trash Cougar's Avatar
    They do and their are. Some people complain that when you take a turn fast, the weight can cause it to swing around and twist your seatpost. Others don't have this problem. I suppose if your seatpost collar is nice and tight, it probably won't be a problem.
    R.I.P. Ronnie James Dio ~ July 10, 1942 May 16, 2010
    Quote Originally Posted by Gary the No-Trash Cougar
    I use a Bontrager seatpost rack.
    http://bontrager.com/model/06971
    It uses hex bolt top clamp on to the seatpost, so it fits nice and tight. I attached a couple of bungee cords from the rack to the chainstays so I can use panniers. It's worked out well so far.
    Frt Range, CO
    Reputation: pursuiter's Avatar
    Quote Originally Posted by jayfromqns
    ...It uses hex bolt top clamp on to the seatpost....
    That's what I have and it holds tight even when only one side is loaded with a 12pack of beverages. Everytime I read someone complain they don't hold tight, it's the QR version.
    Good job!
    I forgot to mention that I cut a piece of inner tube between and placed it between the clamp and the seatpost, this helps prevent the rack from swinging on sharp turns.
    Just wanna update you guys that I got some P-Clamps for the seat-stays and reuse my old Blackburn rack. All is well...
    One Colorful Rider
    Reputation: Normbilt's Avatar
    Bolt on regular racks are more Stable.
    The only reason to use a Seatpost rack would be for a Full Suspension Bike.
    Bolt on racks are cheaper
    Quote Originally Posted by Normbilt
    I'm going to have to argue that piont. I love my seatpost rack because I can easily take it off and put it back on whenever I want with hardly any effort and no tools. I'm actually going to get a new version of the rack I already have from Topeak. I bought it for a mountain bike I got for free that really never fit me and molded a light onto the back where the reflector originally was. If you want something simple and easy to switch between multiple racks go with a seatpost mount.
