small rack/pannier-esque setup on my 29er- Mtbr.com
Results 1 to 13 of 13
    Still waiting for some pannier hardware to modify the goggle cases.
    M_S
    M_S is offline
    Nov 2007
    Cool setup. Is that the nashbar front rack?
    Thanks.Yep, Nashbar front rack. Ordering another for the front.
    weirdo
    Reputation: rodar y rodar's Avatar
    Cool! Very good idea, Mijome!
    Thanks.
    How is that seat post? I'm thinking about getting one for my commuter.
    It's great. I highly recommend it. Easily adjustable. No pogo effect.
    All done. Rack, cases and hardware came out to about $65. Setup is super-sturdy.
    Once the bungee breaks in, I'll trim the excess. One can be used as a trunk bag.
    Found a few mounting brackets in the garage that fit perfect. And they're black.
    Here is the modification all finished. Gonna add a PB tail light on the rear.
    weirdo
    What are the bags you`re using? They look a little like camera/video cases.
    Also, a suggestion for mounting DIY luggage. I`ve got a few bags that I screwed Lone Peak pannier clips onto. They have a small hook that rotates around a tube to lock on and are available for either 5/16 (8mm) tubing or 3/8 (10mm) They do cost more than the rubber coated clips you have there, but still not too bad. I bought them from thetouringstore.com for $20 per four clips plus a few bucks in postage IIRC. They aren`t listed on the website, but if you call or email he`ll ship you some.
    I have to say again that I love the idea of the rear mounting for Nashbar mini rack!
    They are goggle cases. This is my 1st attempt in modifying any bag/case. So far, it's good. I'm open to changes. I'll check those clips you mentioned. Thanks.
    One Colorful Rider
    Reputation: Normbilt's Avatar
    Saw this in the Salsa booth at Frost Bike 2010
    Cool, but I wouldn't use it. For the same reasons I didn't get any Nitto mini racks. Price and the need for p-clips.
    weirdo
    Yeah, that is cool. You`re right that it`s expensive- looks like $75 MSRP. I think it`s much prettier than the N-bar rack, but you can`t beat $10! P-clips might not be needed though. Maybe they offer legs to mount the same rack to canti studs?
