SKS fenders. fixing a warp?- Mtbr.com
    Sep 2015
    i'm installing fenders now..well, i'll finish tonight, now that i have my bolt cutter in my truck.
    but looking into the future, the front fender looks twisted to on side. i dont shouldnt have any rubbing issues, but it will drive me insane visually.
    if you've never installed fenders, you pretty much render them nonreturnable right at the get-go. (i had to bend a tab to clear my steering bottom bushing cup thing).
    i'm gonna try my wife's hair dryer and warming it up some. any tips?
    sorry, i didnt know what subforum to put this in..hope i'm somewhere in the right neighborhood with you commuters.
    Santa Cruz 5010 C
    Surly Crosscheck.
    Try to adjust the stays holding the fender together on one side, in conjunction with slightly loosening the crown bolt. They are rarely warped, but instead have a warp added(?) to them due to non-careful installation. Not a dig at you, mind you, just something to be aware of. Hold the crown mount while tightening the bolt, and be sure to use a washer under both the bolt head and the nut.
    If that fails, a heat gun on high heat (or a hair dryer, takes way longer) can be used to soften, then set, the plastic.
    K_W
    K_W is offline
    May 2015
    They should be thermoplastic, very easy to correct... if they are warped, heat gently with an hot air gun until softened, twist back to normal, then twist a bit more past that and run under cold water. When you let go it will relax and should be better than it was.
    Sep 2015
    Hot water did the trick. Thx
    Sent via Jedi mind trick.
    Santa Cruz 5010 C
    Surly Crosscheck.
  1. Warp Speed
    By cyclelicious in forum Downhill - Freeride
    Last Post: 05-24-2014, 04:18 PM
  2. Replies: 1
    Last Post: 02-22-2013, 01:00 AM
  3. does anyone wanna buy a warp?
    By jakester29959 in forum Downhill - Freeride
    Last Post: 10-03-2011, 08:26 PM
  4. wheel warp
    By james_hetfield in forum General Discussion
    Last Post: 07-12-2011, 07:43 AM
  5. Rotor warp Q
    By C.M.S in forum Beginner's Corner
    Last Post: 07-09-2011, 04:51 PM
