Road tubless?- Mtbr.com
Results 1 to 12 of 12
Thread: Road tubless?
    blet drive
    Reputation: JUNGLEKID5's Avatar
    Road tubless?
    Any one out there running road tubless with success? I find that over 40-50 psi the sealant won't build up fast enough to stop a leak. Any thoughts? Oh I am using stans if that helps.
    Save a tree & wipe your butt with an owl.
    Thank your local Sierra Club.
    Reputation: LargeMan's Avatar
    May 2017
    Yes, all the time. Road tubeless does not need sealant.
    sofa king awsm
    Baby, I want my face to be your quiver killer.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Quote Originally Posted by LargeMan View Post
    Neither does mountain bike tires until something pokes it good.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    replacing a tube and carrying a pump is just too easy for me....YMMV
    Magically Delicious
    I'm tubeless on road and trail, but I always carry a spare tube and a pump to accommodate those times when they're needed.
    Apr 2013
    I ride tubeless on the road - 700-35c Schwalbe G-Ones. I do use Orange Seal sealant, and run them around 40-50 PSI. They've definitely plugged some small punctures (rode through a pile of goat heads and probably picked up half a dozen). In those cases the drop in pressure wasn't significant enough for me to have to stop and pump back up.
    blet drive
    Thanks for the updates guys. I a now trying a new sealant from slime. So far so good. Time will tell. I did set up a reminder in my phone to add sealant in about 5 months.
    Jun 2012
    My experience agrees that tubeless works best at lowish pressure but that's based on experimenting with different pressures on the MTB rather than trying a dedicated road tubeless setup. I do ride the road tubeless and find that tire plugs work well for larger punctures or if I've let the sealant dry up too much.
    Magically Delicious
    ^^^ Just my trying to understand your inference.
    Are you saying that you believe sealant works at 'lowish pressures', but perhaps, not so well at higher pressures?
    Jun 2012
    Yes, I've had better luck with Stan's self-sealing punctures at ~25psi and below than at 35 - 40psi.
    Reputation: ghettocruiser's Avatar
    A few years back when road tires were still 23C @90PSI, I thought it was pointless.
    Now that my "road" tires are 30C at 50PSI on a rim that makes them even wider.... no tubes for me.
    It doesn't hurt that my road tubeless were so easy to get on and off the rims, I actually got scared and double-checked I had really bought tubeless tires.
    The above statements have not been evaluated by the Food and Drug Administration
  1. Tubless w/ non tubless tires?
    By centershot in forum 29er Bikes
    Last Post: 01-17-2014, 09:45 AM
  2. Road Road Road
    By randyharris in forum Arizona
    Last Post: 05-21-2011, 12:55 PM
  3. Halo freedom disc tubless?
    By fixgeardan in forum 29er Bikes
    Last Post: 02-02-2011, 01:32 PM
  4. Bontrager tubless rim strip compatibility??
    By jcmtbfreak in forum Wheels and Tires
    Last Post: 02-02-2011, 11:04 AM
  5. 2011 Easton EA90 XC wheelset TUBLESS DISK 29 29er
    By xterracj in forum 29er Bikes
    Last Post: 01-11-2011, 06:01 PM
