• 11-28-2011
    GregoryMB
    Road tires for mtn bike - which size Big Apples?
    Hi guys,
    I'll be building a singlespeed out of an old specialized allez in a few months, but in the meantime I'm doing a ton of commuting on my Scott Scale elite 29er. I use nevegals on the trail, but don't want to wear them down too quickly.
    I've decided that the schwalbe big apples look like a lot of fun, and are pretty quick. They make the tire in a 2.0 and a 2.35. Given that I want to be able to use my front derailleur, I'm thinking I have to go with a 2.0 in the back. I assume I'll do the same up front, but is there any reason to put the fat 2.35 up front? I always seem to see the wider version of these tires, and I haven't heard from many people with the 2.0s.
    Thoughts?
  • 11-29-2011
    CommuterBoy
    I say go as fat as you can. I have the 2.35's on both ends of my Access 29er. I can fit a front derailleur even with fenders (did it when the bike was in 'touring' mode), but I don't use one on the commute. The bigger, the squishier. I love these tires, you'll have fun riding them either way.
  • 11-29-2011
    jeffscott
    If you are not riding gravel just asphalt...then go narrow and hard...way more fun....38mm slicks just rail corners and are way fast.
  • 11-29-2011
    eBikeStop
    I ride a 2.0 big apple on the rear of my commuter. However, due to the trail that I take to get to work, I use a 2.25 Michelin Wild Racer (old version) on the front because of the dirt parts. I like the slick rear for the reduced friction and noise. What are you riding on? If it is all street style then I agree with jeff. Narrow and Hard. You will love the speed increase.
  • 11-29-2011
    Dogbrain
    I run the Forte Metro-K on 29r rims for commuting in the winter. They are nice and I even take them on short sections of gravel/hardpack. Very flat resistant and you can get a full set for half the price of Big Apples. They are large enought that I feel confident when riding over cracks in the road, drainage grates, etc., yet thin and hard enough to roll really nice. There are other Forte tires with larger volume.
  • 11-30-2011
    GregoryMB
    Thanks guys - my commute is all asphalt (unfortunately). Sounds like 2.0s might be the way to go. I'd love to take a spin on the 2.35s but I'm just not sure they're as practical for a commute.
  • 11-30-2011
    slimhazy
    I have the 2.35s on my Karate Monkey. They're enormous. I've also used the Serfas City Drifter in 29x2.0 and like them a lot, but they're not as slick. I think that size in the Big Apples might be better all-around for commuting.
  • 12-01-2011
    canyoneagle
    The speed increase is largely perceived rather than real, particularly in the context of commuting, where real world conditions pretty much negate any increase in riding speed.
    I would agree that narrower tires at higher pressure "feel" faster, perhaps because they feel "livelier". No doubt there - narrower tires have a different feel that many like. I love the feel and sound of 23-25mm tires spinning on a well built wheel - it is intoxicating.
    However, for my commute, with potholes, pavement seams, rocks, gravel, glass metal and a mixture of route options, me likey my fatties.
    My commute time is not influenced by my choice of bike or tires - it is literally exactly the same, whether I'm on my road bike or on my 29er with 2.35 big apples. In truth, I have way more fun on the bike with the 2.35's <<<<for commuting>>>>. Now, if we're talking about a weekend ride up Big Mountain Pass? Bring on the road bike, baby! ;)
    So - I'd say go as big as you can - I've commuted on everything from 23's to the big apples and fat is where it's at, IMO. If you can fit 'em, give the 2.35's a try.
  • 12-01-2011
    Spinnyspinspin
    Each Big Apple does weigh about a pound (the 2.35's are 75 grams heavier than the 2.0's), so if that kind of thing matters to you at all might be a deciding factor. I have a co-worker who runs the bigguns on his Monocog and he loves them. Not Schwalbe's highest level of puncture protection, but they make damn good tires.
  • 12-02-2011
    bikefun
    What did you decide on? Curious about the Scwalbe's.Nice tires but I always thought of them being heavy and not very agile. Thoughts..?
  • 12-02-2011
    eBikeStop
    I have found narrower tires to make a major difference in my commute time. I do agree that outside conditions can factor. The tire change for me on a 25 min commute (all bike path) brought it down almost 4 minutes on average. Especially since Gregory mentioned that he is on all asphalt (no mixed routes), the tire can really make a difference.
  • 12-02-2011
    GregoryMB
    Well, I haven't put in the order yet, but I am leaning toward 2.0s. I am reticent to go through with it because of the 2.35 fun factor. I find out in a couple months where I'll be moving, and the bay is a real possibility. With those hills, I'm thinking the 2.0s will indeed be smarter...then again, I could be in chicago. Polar opposites I suppose.
  • 12-03-2011
    JAGI410
    I have the 2.35's on my Xtracycle and there are times I wish I would have got the 2.0's instead. The fender clearance is very low, and I've got stuck in the mud a couple times because of that. The 2.0's at 40psi would be plenty fast and comfortable for everyday use, or pump them up to 55-60 for extra speed.
