Removing Debris from Tire Casing- Mtbr.com
Results 1 to 5 of 5
    jrm
    jrm is online now
    Reputation: jrm's Avatar
    Im using WTB All terrainasuaras's on my CX bike for commute and dirt duty. I ran over a piece of wire about 3 weeks ago. When i first inspected the tire casing i found and removed what i thought was the piece of wire.
    Since then ive had two slow flats which tells me i didnt get all the wire out of the casing. Ive turned the tire inside out and used a magnifying glass to inspect the tire but can find the culprit. I can locate the approximate location of puncture but not the wire. Im looking for ideas on how to get to the wire and remove it.
    Its either look for it or trash the tire because this is getting rediculous.
    Cheers
    Yeah, I think this is more about the tire than the situation. I've had similar issues with my 26" All-Terrainasaurauses.
    jrm
    jrm is online now
    No kidding
    Quote Originally Posted by Schmucker
    Like the tires. What did you end up doing.
    Getting different tires that didn't flat every day even though I couldn't find anything in the tires.
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    Coulda Been the Wire
    Wire is nasty stuff, it can even flatten car tires....at the places that shred up old tires down to,small chunks, the pieces of wire from the chopped up radial tires cause car flats all the time.
