• 10-04-2011
    rockhound
    Recommend a disc-only 26" mtb frame that fits 700x42 tires
    Can anyone recommend a disc-only 26" hardtail frame that will fit a 700x42 in the rear stays?
  • 10-04-2011
    jrm
    Only one i can think of
    is the Salsa Ala Carte.
  • 10-04-2011
    rockhound
    I think I've read that before and forgot, thanks for mentioning it.
  • 10-04-2011
    rockhound
    I have a feeling that the newer Treks or Fisher 26" frames may because they don't have seatstay or brakestay bridges, but don't have one to test.
  • 10-04-2011
    SpiderMike
    Seen it done to a Surly 1x1. I think the Surly Troll has the same amount of room.
  • 10-04-2011
    Mr Pink57
    The Troll should easily be able to do it.
  • 10-04-2011
    rockhound
    Neither are disc-only, but I know they fit a lot of tire.
  • 10-04-2011
    rockhound
  • 10-05-2011
    Lewy
    Any reason it has to be a 26" frame? Wouldn't a 29er frame be easier.
  • 10-05-2011
    rockhound
    I already have a rigid 445mm fork I'd like to build this around and wouldn't mind the shorter wheelbase of a 26" bike and I think they are more flickable. I have run a few of my 26" hardtails with 700x28 and 700x32 tires for years and love 'em.
    The only 29ers that I know would work with this 445mm fork would be the early Raliegh XXIX (heavy frame) or an OS Blackbuck (not cheap).
    Besides, I figured a used 26" hardtail are less desirable and hence "should" be cheaper than a 29er.
  • 10-06-2011
    Normbilt
    Surly 1x1 with 29x2.1 slash 700x54 tires with disc Brakes
    Tuesdays Ride by normbilt, on Flickr
  • 10-06-2011
    rodar y rodar
    If you happen into a steel frame that fits your other needs, you can move the bridge up and out of the way. To completely skip the bridge sounds kinda crazy to me, but I`m not an engineer.
  • 10-08-2011
    rockhound
    I have a Werks Haro Werks SS that I could do this to but I'd have to wait for an Alfine wheel.
    if it were brazed and not tig welded I might have already.
  • 10-09-2011
    Jeff Stevens
    I have a 1x1 that I have done 700c 37mm tires but I thought the bike handled funny with that set up. I prefer it with 26" tires.
  • 10-09-2011
    Normbilt
    Mine did not ride weird. I like the fact that it was a lower center on gravity.
    But then I found this bike true Identity meet the Joker
    New Sneakers and Post by normbilt, on Flickr
  • 10-10-2011
    9erfreak
    That is sexy...
