• 01-26-2009
    scslpt
    Rear Rack Recommendations for CX Bike lacking eyelets
    I need a recommendation for a rear rack for my Redline Cross Bike. It lacks eyelets. Ideally, I'd like to mount via the cantilever brake mounts. Old Man Mountain Sherpa racks are too steep; my last rack was stolen right off my bike and I don't want to drop $110 on a rack that might get stolen. Any other recommendations?
  • 01-26-2009
    ranier
    The OMM racks are the only ones that come to mind. I've got one on my commuter that uses the cantilever mounting. Pretty sturdy stuff.
  • 01-26-2009
    Schmucker
    OMM. Canti and axle mounting. Use torx fasteners so it cannot be removed, or run your lock through the rack.
  • 01-26-2009
    sonoranbiker
    You can also go the cheap route; buy a regular rack, go the hardware store and buy some pipe clamps (many racks come with these, but the ones from the hardware store are beefier) then just bolt the rack on.
    OMM racks are burly and well-made, but also really expensive.
  • 01-27-2009
    scslpt
    Thanks for the info folks... I think I'm probably leaning towards spending the money on the OMM rack. Its a really nice rack and the torx fasteners are a good idea.
  • 01-27-2009
    jgsatl
    http://www.axiomgear.com/product/racks/
    axiom makes racks that don't require braze ons....
  • 01-27-2009
    chemguy
    Would a seatpost-mounted rack give you enough load capacity?
  • 01-27-2009
    achiral
    Another option would be to go with the Tubus quick release mounting kit.
    It might be possible to modify for other rack systems, but I have not seen the pieces in person.
    The OMM racks are of very high quality and the axle-mounting is secure even with >50lbs of gear loaded on a rack.
