Picked up a new commuter project. Need advice.- Mtbr.com
Results 1 to 26 of 26
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    Found this guy at a garage sale for $40 and decided I had nothing to lose. This will be to replace my Gary Fisher in my signature below. I want to ride with my roadie buddies from time to time but mostly this will be for to and from work and getting a workout.
    It needs a new rear tube and tire. Possibly a new front tire. New bar tape. New saddle. Rear skewer(Already had that).
    If you have suggestions for a commuter please let me know!
    It is all aluminum(fork might be carbon), Full tiagra 9 speed(chainrings and cassettes look new), Mavic rims(not in the best shape). But its a 56cm which fits me perfect and no cracks or dents in the frame.
    From what I can tell, its a 2004 R400, but all the info i find on those have Sora components. Any ideas?
    I'd rather be on my bike
    Reputation: TenSpeed's Avatar
    Feb 2012
    For $40 I would say that you really cannot go wrong there. Nice score!
    The pedals turn, not just the left one, but the right one too.
    Reputation: Texan-n-Fla's Avatar
    Sep 2013
    Give ya 50 for it
    Excellent score. Replace what needs to be replaced and keep the rest. Those older USA Cannondales can't be beat, man!
    Bourbon: Because no good story ever started with "So, there we were eating salads".
    I ride bikes
    Apr 2013
    You guys think I should go with 23c tires or go with something a little bigger?
    Also, Good cheap bar tape?
    Reputation: antonio's Avatar
    Jan 2005
    Wow. Nice find.
    If it were mine, I would:
    1) Consider getting 25c or 28c tires, if they fit in your frame/brakes. More comfy, lower rolling resistance, less chance of pinch-flatting.
    2) Try out a stem with less angle, possibly flipped. I'd want to be less upright (a little more aero) while still being comfortable.
    3) Keep the bar-tape you have on there, and wrap a second layer of bar tape over that first one.
    4) The levers seem to be too high up on the bar. I'd probably lower them. That way you could actually reach the levers from the drops.
    Congrats!
    Sep 2013
    I run 23's, but have no problem running 25's or 28's when the bug hits. I've also got some 35 Maxxis Raze knobbies that have been worn down to slicks that I toss on every once in awhile. Talk about a cushy ride!
    Lizard Skinz has some great bar tape. Wrap that over the tape you have already, and you'll feel like you're cruising.
    And don't be afraid to check out RoadBikeReview, the sister site to MTBR. Tons of great info over there.
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Quote Originally Posted by antonio View Post
    The levers seem to be in the right place. The whole bar needs to be rotated about 35deg down. The ends should be parallel to the ground.
    Reputation: Straz85's Avatar
    Awesome deal for that bike! That's a seriously high stem!
    I ride bikes
    Apr 2013
    Quote Originally Posted by Straz85 View Post
    That's what I was thinking. might try to find something that is more useable.
    I ride bikes
    Apr 2013
    Quote Originally Posted by Shayne View Post
    Thanks for the info! If I went to a flatter stem would that lower the front end too much in relation to the saddle height?
    Jan 2005
    I agree that the bar needs to be rotated, but the levers still seem high to me.
    Jan 2005
    Quote Originally Posted by moefosho View Post
    Depends... on your arm/torso length, level of flexibility, personal preference.
    Some people run bars level with their saddle. Others run a 5+ inch drop from saddle to bars.
    I ride bikes
    Apr 2013
    Will the stem need to be 25.4 or 26mm ?
    If the bars were rotated then the levers would be in the right place. The tips are approx. parallel to the bottom part of the bar. When the whole shebang is rotated then it should look/feel better.
    Stem will most likely be 26.0, maybe 31.8, for sure not 25.4.
    Go with what's comfortable. It doesn't hurt to try riding it with that stem.
    I ride bikes
    Apr 2013
    Like this or is that too much?
    There's no right or wrong, whatever works for you. That being said, that's probably too much for most riders. You typically want to start with the top of the bars level with the ground or just pointing very slight down. Look at some pictures of road bikes and you'll see.
    Reputation: rogbie's Avatar
    Just about right! As was said, personal preference will dictate where it all ends up. I set my bars with the barends pointing at a point just above the rear dropouts.
    A longer stem (~10mm longer) with less rise (~5*) will help handling. The saddle looks a little high in the nose. But personal preference...
    I ride bikes
    Apr 2013
    Ordered 2 Hutch equinox 2 25c tires.
    2 Continental tubes
    and a Selle Italia SLS Kit Carbonio Flow Saddle.
    Now I just have to wait till they arrive.
    Don't forget the stem!
    I ride bikes
    Apr 2013
    I snagged a stem from my buddy.
    Re: Picked up a new commuter project. Need advice.
    Doesn't matter how the flat part of the drops are lined up. You spend so little time riding the drops I wouldn't let that be the deciding factor.
    I prefer my wrist to be a more neutral/natural position. I.e. not twist wrist so my thumb is lined up with forearm. So my hoods are tilted slightly up. The brifters could come down a bit but works for now and may change it when I need new bar tape. But that is what works for me.
    Fit is much more critical on a road bike vs mtb. When you get the saddle height & position set, with cranks parallel to ground, you should be able to take hands off hoods and keep same body position without too much effort.
    Bring tools on your first few rides to tweak adjustments. Ride the snot out of that bike hell of a find and for $40 you damned well stole it
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    Here's some info on serial numbers and old catalogs that might be worth perusing...
    Vintage Cannondale
    Reputation: newfangled's Avatar
    Great score!
    With the original stem and bar setup, the original owner was probably trying to compensate for fit issues. The next step would naturally have been:
    I ride bikes
    Apr 2013
    Thanks for the help guys!
    Its actually a 2003 R400 Caad4, but the previous owner must have put all tiagra parts on it.
    ~ B A D A S S ~
    Reputation: car bone's Avatar
    That bar will give you either level top or level drops, I prefer both of these to parallellish. I would get a more "modern" bar.
    'that being said, I have my brakes tilted even more down than that, but I never use the hoods, only the drops or the flat "fixie hipster" part. But for more allround use the brakes should come up an inch or 2 I guess.
    The saddle angle depends on if you want to be in the drops a lot or on the hoods/flat imo. tilt it down/forward more for in the drops position.
    nice find!
    Rule #9 // If you are out riding in bad weather, it means you are a badass. Period.
    Quote Originally Posted by iheartbicycles View Post
    Specialized sucks ass.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Do yourself a favor and buy a compact bar for that thing. I actually have cowbells on my road & CX bikes. Wider is better
  1. Advice on a commuter
    By nordy643 in forum Commuting
    Last Post: 05-30-2014, 07:03 PM
  2. Project Frederick - My New Surly Ogre Commuter
    By Dalton in forum Commuting
    Last Post: 03-05-2014, 04:31 AM
  3. Picked up a Cannondale Super V700. Could use some beginner advice.
    By alansupra94 in forum Beginner's Corner
    Last Post: 04-08-2013, 05:44 PM
  4. New commuter project.
    By Striper in forum Commuting
    Last Post: 10-22-2012, 08:06 PM
  5. Some advice on my MTB to commuter
    By kumarpr227 in forum Commuting
    Last Post: 04-04-2012, 08:19 AM
