Opinions on whether to replace tire- Mtbr.com
Results 1 to 15 of 15
    Jan 2014
    I've put about 1900km on this tire. Not sure at what point to replace. I have about a dimes thickness of tread left in the center. You can see I still have the nubs on the sides.
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    If you're just using it to commute you've probably got another 1000k waiting there.
    You can ride that until the center section is slick. I usually don't replace until the chords are showing.
    More than a little slow
    Reputation: dskunk's Avatar
    I also think you've got a lot of life left in that tire. If you start getting frequent flats then replace it, otherwise ride 'til slick.
    Cheers, Dave
    If you are made of money, obsessive-compulsive and wasteful, replace it.
    Otherwise it has tread and plenty of life.
    ~ B A D A S S ~
    Reputation: car bone's Avatar
    Replace it immediately with either Schwalbe marathon supremes or Continental contact 2!
    Rule #9 // If you are out riding in bad weather, it means you are a badass. Period.
    Quote Originally Posted by iheartbicycles View Post
    Specialized sucks ass.
    Aug 2014
    If you are riding mostly pavement, replacing that tire with something higher psi in a smoother tread will feel a lot like taking the tire chains off your truck.
    My switch to Continental Town and Country tires (65 psi, 26x 1.9, less than US$50 for the pair on Amazon) has been worth every penny. The folks above are right, you are in no danger with that tire, however, new smoother tires might be a lot more fun.
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    I think it also depends on your tolerance for flats, and your workplace's tolerance for tardiness. If you don't always leave early enough to fix a flat and be on time, or you're likely to lose your job if you're late, I'd say it is well worth buying a new tire.
    Feb 2013
    Replace it....a dime amount of tread.....no bueno.....
    Wierdo
    Dec 2005
    I ride road slicks on my commuter and usually get 4000-5000 miles (6400-8000km) out of a rear tire. That tire has a lot of life left in it.
    Jan 2014
    updated pic
    I have examined the tire more closely and have notice 3 of these little cuts in the tire. Does that change any opinions? Suggestions for a wider commuter type 650B tire. I just think a tire that is 35mm wide would look funny on a mtb.
    Quote Originally Posted by snailspace View Post
    Carry a tube ride it til it flats go buy a slick now for the asphalt pavement riding...get over yourself about how things look.
    That's not a cut.
    THIS is a cut
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by Tan&Green View Post
    it's a bike, dude. ride it till it's bald (or you're getting too many flats for your liking).
    ~ B A D A S S ~
    Quote Originally Posted by Shayne View Post
    That's not a cut.
    THIS is a cut
    The kevlar lady was on vacation when they made your particular tire or is it only the bead that is kevlar??
    Good question since it has no bead?!?
    Generally only the bead is Kevlar though unless the tire specifically mentions a belt of it.
  1. Replace rear Tire?
    By rickcin in forum Wheels and Tires
    Last Post: 11-06-2013, 03:06 PM
  2. Replace Front Tire + Rim Only?
    By MTBkitty in forum Wheels and Tires
    Last Post: 06-12-2012, 05:58 PM
  3. Is it Dumb to Replace Only One Tire?
    By cohenfive in forum Wheels and Tires
    Last Post: 05-14-2011, 08:32 AM
  4. Help me replace my front tire
    By Jhilton in forum 29er Bikes
    Last Post: 05-07-2011, 08:49 PM
  5. Do I Have To Replace My Tire?
    By krinksta in forum Beginner's Corner
    Last Post: 04-13-2011, 08:17 AM
