One set of tabs with fenders and a rear rack?- Mtbr.com
Results 1 to 6 of 6
    I am looking at buying a winter bike and many have had only one set of eyelets on the rear. Is it possible to add a rack and fenders with only one set of eyelets? Can fenders be attached to a rack?
    I have never had a rack but may want to get one in the future.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    I just use a really long bolt. Done and done.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Fender struts under rack struts , bolt length to suit .
    I was thinking that may work. Thanks for confirming!
    I have mounted fender on just about every bike made over the past 20 years, having the time and patience is another thing. Any good LBS should have a stock pile of seat stay reflector bracket mounts, which are good for adapting fender mount struts without using brazed eyelets. LBS may let you look at their miscellaneous brackets/hardware (junk drawer) too…should be able to find some good stuff there as well.
    I actually run a full length set of SKS’s on my ATB in the winter, it is a hard tail so it's easier to mount the rear fender, but you should see some of the looks I get with my front full length fender on my SID World Cup...hilarious! It does look kind of goofy but I am usually the one who is dry on our wet rides.
    Which way? Uphill.
    Reputation: nepbug's Avatar
    Sep 2004
    Quote Originally Posted by AZ.MTNS
    This is the order I put them in too, it worked the best for me. Otherwise the rack got in the way of the fender struts.
    Blog
    Just keep spinning. Just keep running. Just keep paddling.
    Just keep moving forward.
