Oh crap. Did I order the wrong part?- Mtbr.com
Results 1 to 6 of 6
    Jun 2012
    I ordered the below but I intend to use an Ultegra cx70 front derailleur and a 105 rear derailleur. Will these shifters really not work with that front (and rear?) derailleur?
    And why the $#@! is Shimano being so screwy with their parts compatibility lately?
    Shimano Dura-Ace 7900 BS79 Bar End Shifter
    Bar-end Control (Bar-Con) shifters for road drop or aero type bars
    Rear shifter convertible between index and friction action (BS79 shifters only compatible with Dura-Ace 7900 front derailleur due to revised cable pull actuation)
    Includes cables and housing
    weight: 165g
    color: grey/silver
    speed: 2x10sp
    model: Dura-Ace BS79
    weirdo
    Reputation: rodar y rodar's Avatar
    I`m pretty sure you`re good as long as you have a 10s rear cluster, but that is kind of weird. Friction shifters usually don`t care what they shift, but ya never know. That model is apparently the new ones that don`t have a friction mode for the rear though, so I don`t understand why they still claim dual mode in the description. I don`t see 7900 on the current Shimano website, but the tech that I found just says "recomended" for DA front derailler. Here`s a thread that popped up concerning the same issue:
    Anyone successfully using Dura Ace SL-BS79 Shifters with Ultegra 6700 Front derailleur: Triathlon Forum: Slowtwitch Forums
    The main concern is if you can't pull enough cable to make the derailleur move far enough. I'm guessing that there's a good chance you can clamp the cable in the front der in a manner other than intended that will allow it to work. This will work if the dura-ace derailleur is supposed to be paired with a shifter with low travel, high tension cable movement.
    More likely it will just be hard to pull the shift lever; dura-ace has been moving towards high travel low tension cables ( at least for brakes), so my guess is that worst case scenario is that you have to pull the left barcon lever a little harder than usual and not as far to accomplish the shift.
    Jun 2012
    Apparently the front is friction only while the rear is now INDEXED ONLY. Which is weird. How are the tourist to go to 10speed?
    Supposed to be compatible with everything road though.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by aBicycle View Post
    You use a different front shifter for a triple, if the M79 is indeed 2x only.
    You sure have a lot of questions for somebody that has been riding for 92 years.
    mtbtires.com
    Jun 2012
    I think it can do a triple actually.
    And it's all these damned new fangled parts! I mean, how many ****ing different standard and ways of doing things does there need to be??!?!??!?!
