Normal for rack bolts to come loose?- Mtbr.com
Results 1 to 5 of 5
    Reputation: djork's Avatar
    Just got back from a grocery run, and after unloading I went back to unstrap the U-lock and that's when I noticed that the rear rack was a bit loose. I'm thinking didn't it have a solid feel before? I then inspected the rack and nudged it here and there and soon found the problem. One of the bottom bolt that bolts the rack leg to the drop-outs fell off and the other one on the other leg was on the brink of falling off! I tightened that one back and for the missing bolt I got one of the two unused water bottle bolts.
    My question is this normal? I'm thinking the vibration must have done this. How can I keep them on snug and tight?
    No-Brakes Cougar
    Reputation: Gary the No-Trash Cougar's Avatar
    Yup, it's just vibration. Things shake loose, it happens. Just tighten the bolts good and tight without bunging the heads and it should be fine. If it becomes a persistent problem, you could try some thread locking gunk like Loc-Tite but it probably won't be necessary.
    R.I.P. Ronnie James Dio ~ July 10, 1942 May 16, 2010
    weirdo
    Reputation: rodar y rodar's Avatar
    Yeah, I have trouble with them too. For some reason, they seem to me more vibration prone than any other bolts- no idea why. I now put Loc-tite on all of mine (brake bolts too) and use lock nuts on through-bolts. If you do that, just make sure you don`t use the super strength permanent stuff.
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    +1 on the loctite
    "If women don't find handsome , they should at least find you handy."-Red Green
    It happens. I check my bolts fairly often, they're never loose, but I'm paranoid. If it becomes a problem, add just a drop of blue loc-tite.
