Never had a rack before.- Mtbr.com
Results 1 to 6 of 6
    Jun 2012
    So, are the panniers supposed to be able to slide back and forth on the rail?
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    Mine lock on pretty snug and don't slide around, but there are a lot of different "attachers" and racks, some more compatible or stable than others. Perhaps something like a ziptie or bungie to limit movement might be of use? Depending what you carry in them in could be pretty expensive if they fly off the rack mid-ride.
    No, you should be able to adjust the position of the latches until everything holds tight.
    Jun 2012
    How do I do that?
    weirdo
    Reputation: rodar y rodar's Avatar
    Cany you post a picture of the mounts? They`re all different. Some aren`t adjustable (mine aren`t). If they don`t cause any problems, I wouldn`t worry about it, but if there`s a danger of losing one or if the position that they try to drift to sucks, one of MtbX`s ideas might work for you. Or a couple wraps of friction tape so that the clamps grab tighter- most clamps are for 3/8 or 10mm tubing these days, while a lot of racks use 5/16 or 8mm.
    It depends on the pannier. Some require a screwdriver, some have thumb screws, some have flip latches. Many require a lower clip to help keep the upper clips in place.
