Need new tires… help a guy out- Mtbr.com
Results 1 to 15 of 15
    Aug 2010
    I've been doing some research, but I need some input. I need to replace the Duro Ellie Mae CX file treads I use to commute on my Carve 29er SL SS.
    I ride about 60% road 40% rough gravel/dirt roads with some decent hills.
    The Duro's have been solid, they just don't wear well and have a bunch of cuts I'm not fond of riding on anymore.
    I need something with at least the same amount of grip but more durability without killing myself in weight and ride quality. I like how these are, just need some more durable tires with similar qualities everywhere else.
    clement x'plor series? Schwalbe marathon series?
    Bicyclochondriac.
    What size (width) you looking for?
    Aug 2010
    probably 35-40c. The ones I have are 35c. I have plenty of room since it's an mtb.
    Bicyclochondriac.
    Just looked up a picture of what you run now. Wow that is a pretty aggressive tread for pavement and gravel roads compared to what I tend to run for similar surfaces. So my recs are probably not what you are looking for, but here you go....
    I run stuff like Conti Contact, Conti TourRide, Schwalbe Marathon Supreme, and Bontrager H2 for what you describe. The one I am most happy with is the Bontrager, because they are relatively cheap, but have kevlar bead and are fairly light, and I just like the ride quality. But all the ones I mention are not as aggressive as what you are now running, but are probably a heck of a lot faster rolling.
    Aug 2010
    It looks more aggressive in pics. The file tread in the middle is minimal, but it is a cx tire. I'll look at the bonty's
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Kenda Kwicker 700c x 32 is the ticket; fast roller, light and perfect for the gravel.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Aug 2010
    How's the durability/puncture resistance?
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    I run the Marathon HS420 on my MTB commuter. I have not gotten a flat yet, they are very long wearing, and they do fine on dirt roads.
    jrm
    jrm is online now
    Reputation: jrm's Avatar
    clement explor MSO or USH and WTB nanoraptor. Ifyour using a mtb width rim just remember that the ti needs to be as wide as the rim.
    Moderator Moderator
    Reputation: Harryman's Avatar
    I wish it had a higher thread count, but this is an awesome dirt/pavement commuter if you don't mind skinny.
    All Terrain | WTB
    Quote Originally Posted by khardrunner14 View Post
    Run tubeless....it's awesome.
    Aug 2010
    Quote Originally Posted by Zachariah View Post
    Yeah I would, but I have to be able to easily swap back to mtb tires for mtb rides until I get a second wheelset.
    Human Test Subject
    Reputation: Volsung's Avatar
    Compass Barlow tires are fantastic. 700 x 38
    Reputation: Spatialized's Avatar
    On my second pair of Clement X'plor MSO (700x40, 60tpi) and ride conditions similar and love them. Smooth rolling on pavement, aired down some they rock on gravel and after 2,000+ miles I have no complaints. I won't say anything about flats for fear of summoning the flat demons, but no complaints in that regard.
    Reputation: rogbie's Avatar
    Check out the Bruce Gordon Rock n' Road tire: 700x43c, skin walls, kevlar bead, classic design and not too expensive.
    They're a dream to ride, as well.
    Or the Kenda Happy Medium: I ride these on my commuter/exploring bike and they work exceedingly well on pavement, gravel, single-track.
  1. Putting slimmer tires in a frame made for wider tires?
    By bowlofsalad in forum Fat bikes
    Last Post: 09-01-2014, 04:04 AM
  2. Replies: 2
    Last Post: 10-31-2013, 08:33 AM
  3. Question about Schwalbe tires to replace stock tires
    By bosco0633 in forum 29er Components
    Last Post: 03-06-2012, 08:40 AM
  4. Replies: 4
    Last Post: 10-07-2011, 05:04 PM
  5. Wider tires, less rolling resistance, what about taller tires
    By HighLife420 in forum Wheels and Tires
    Last Post: 06-01-2011, 06:23 PM
