Which lock do you use?- Mtbr.com
Results 1 to 79 of 79
    bi-winning
    Reputation: rkj__'s Avatar
    I'm curious to see what types of locks people are using to lock up their bikes when they are unattended. Personally, I don't leave my $1000+ bikes unattended, but for my sub $400 commuter, I recently purchased one of these chain locks:
    BIKE GAURD Warden lock
    It was only $30, but it seems pretty robust. I don't think I would be able to cut it with pocket sized tools, like some cable locks. It is also a little more convenient/versatile than a U-Lock.
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    costs a little more than $30 but well worth it
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    The lock may or may not be hardened steel, but the weakest part would be whats holding the lock mechanism to the chain. Get yourself a Kryptonite u-lock instead. Though less versitile, they're lighter and stronger than chains.
    I'm feeling dirty, you?
    Reputation: jonowee's Avatar
    I mainly use my older version ABUS Sinus 46/150 HB 230 U-lock; and if I'm going to somewhere with unfamilar locking-up arrangements or leaving the bike unattended for more than 10 minutes I bring an older version of this OnGuard armoured cable lock.
    I've chosen to stick in a one lock situation with the ABUS U-lock mainly because it's the most reliable lock I have. I like the armoured cable lock, but the keys supplied with the OnGuard lock is rather 'gummy' and I've worn out 2/5 keys they gave me. Plus the disc cylinder in my lock has trouble unlocking unless the lock is under tension.
    But when I wear out 4/5 of my OnGuard keys, it'll become a back-up or another storage lock-down lock; then I definitely start looking for a much more reliable armoured cable lock to take over as my primary lock from the 'heavy' U-lock, maybe from ABUS, Kryptonite or others.
    I do have at home to lock up the bikes for storage an ABUS Diskus 20/70 padlock and 8mm-110mm square chain combo. The biggest problem is that it is my fault for losing 2/3 of the keys supplied and really need to find time to get to my local ABUS locksmith to get new keys cut for me.
    weirdo
    Reputation: rodar y rodar's Avatar
    All my bikes are sub $400. I use a Bell cable lock.
    I use a kryptonite D lock. I like it because it is very quick to lock up. But I think I need to step up my security. I think if you use 2 lock they should be completely different designs. like a D-lock and Chain/braided cable lock
    bi-winning
    Quote Originally Posted by newaccount
    Though I don't think I will buy another lock (I already have a CCM U-lock) I believe the statement I quoted is correct.
    Quote Originally Posted by dobby156
    Probably not a bad idea, as that may force the thief to employ two different methods or sets of tools to get your bike.
    bi-winning
    Working at a bike shop, I've had the opportunity to cut several locks off of bikes (people lose keys), and I have yet to have any trouble with our gigantic bolt cutters.
    The most popular locks are pretty lightweight/cheap cable or chain locks. Having something that I deem to be a step above the norm gives me a little piece of mind, even though I know my lock is far from immune to theft.
    LCI #1853
    Reputation: PscyclePath's Avatar
    Kryptonite New York 3000 u-lock, or one of the Fuhgeddaboudit chains. Short in and out trips where the bike isn't out of sight, I use a key-locked cable.
    Ride a mountain bike... you will not regret it if you live.
    (with apologies to Mark Twain & The Taming of the Bicycle)
    occupation : Foole
    Reputation: Fuelish's Avatar
    I use the replacement lock Kryptonite sent me when they had their exchange program goingon a few years back (if you had a registered lock of the old key design, they exchanged it for a new keyed design - excellent public relations/customer service, if ya ask me .... the lock they sent is better than the old lock (a lil bigger/beefier, as well as more secure - can't open it with a Bic pen...heh) This, I always use ..... if I'm locking in an area I feel needs more security, I use a cable lock as well (and when I'm feeling paranoid, I lock the padlock through the front rings, have the bike in big ring/small cog to thwart fast getaways, and I undo the brake cable noodle *yeah, still have v-brakes), just in case bike gets cable/lock and u-lock undone and they pedal off in high gear - surprise surprise if they try to stop. YEAH, I'm a bit paranoid, at times ...... especially since I've never had a bike stolen from me ..... yet...LOL
    Reputation: EvilScience's Avatar
    Kryptonite New York Fahgettaboudit U-lock
    Remove front wheel, lock through frame and both wheels. If I'm feeling paranoid I'll add my backup lock, but honestly, I've locked both my commuter (Kona Smoke) and my nice cyclocross bike (Jake the Snake) all over Toronto with this lock with no problems at all. The Titus Motolite does not get left anywhere, ever, unless it is locked INSIDE my car.
    I Rode a Metric Century!
    Reputation: New to MB's Avatar
    Dec 2008
    I ride to work, but we actually have bike lockers. and the security manager has an office window right by them. So I am very secure. I have also brought my bike into my office when I forgot the locker Key.
    No-Brakes Cougar
    Reputation: Gary the No-Trash Cougar's Avatar
    I just have a MasterLock cable lock. I rarely have to leave my bike outside, and when I do it often is for no more than a few minutes.
    R.I.P. Ronnie James Dio ~ July 10, 1942 May 16, 2010
    Reputation: pogliaghi's Avatar
    U-lock works fine for me. I've had a Kryptonite Evolution LS since '97. Swapped it out with the newer (non-cylindrical) key as part of the Kryptonite settlement. I just make sure to remove front wheel and lock with frame and rear wheel. Knock on wood, I haven't lost a bike yet parking in SF, Oakland and Berkeley.
    I use the big Kryptonite NY lock chain. I don't mind the weight and it's flexible in terms of what it can go around.
    Big U lock made my trelock!! Only way to protect my beloved bike!!
    Quote Originally Posted by Adistar
    Three locks?
    No-Brakes Cougar
    Now there's a man who's enthusiastic about his u-lock.
    Quote Originally Posted by Gary the No-Trash Cougar
    Am quite enthusiatic! something was going on with the server and I thought the message wasnt sent hence the multiple posts
    And I would guess you're quite enthusiastic about your bike enough to keep it as secure as possible. I like the MB600, it looks like a tough lock.
    I'm gravity challenged, adrenaline deficient, and looking for that endorphine high. Shout out, I'll move out of the way. :-)
    No-Brakes Cougar
    No worries man, things happen.
    How easy is it to bust your typical kryptonite u-lock? I live in chicago (apparently the 2nd worse city for bike theft besides ny?) and a girl that locks her bike near mine every morning at the train just lost her bike. Not sure what it was but she said it was valued around $350, and she always used a kryptonite mini lock. I know she knew how to lock her bike because I had seen her do it plenty of times. Then one day (happened between 8am and 5pm) her bike was gone, along with the lock. The upside down U bike rack was still intact. So besides having a tool such as rkj's in the pic above, is it really that easy to defeat these things? (if you know how, you don't need to explain, an answer of "i've seen it done in 3 min." would be sufficient, given that you would be providing info to anyone with access to the web). I have a '96 gary fisher hard tail, and although it probably isn't worth more than $100 today, I'd be furious if it got stolen. I am now using a second u-lock borrowed from a friend.
    There needs to be a national law that you lose a hand if you get caught stealing a bike. Maybe we'd finally see a decrease in bike theft. In times where there is a movement (at least from what i've seen in chicago) for people to be less reliant on cars, we don't need the scum of the earth trying to make a few bucks by stealing bikes. I know a lot of people would be more up for taking their bike somewhere if they knew the chances of it getting stolen were a lot lower.
    Quote Originally Posted by zeppman
    If it was an older Krypto lock, you can open it with a bic pen in like three seconds. google it. They did a recall and trade-in thing IIRC.
    No, it was a flat key. I asked and she showed me the key.
    weirdo
    I would imagine that they can be broken in seconds with the right equipment. I`ve heard that people use hydraulic bottle jacks (sounds likely) and I`ve heard of freezing them with a fire extinguisher and shattering them with a hammer (sounds like it MIGHT work). However it`s done, the stuff needed to break a U-lock does not involve bolt cutters or cable cutters, so if you need to lock up your bike in an iffy area, the recomended way is to use both a U-lock and a cable, like Feulish said. THe benefit is that a theif would have to have the needed crap to cut both types of lock in order to ride off with your bike.
    The Gospel According to Sheldon:
    http://www.sheldonbrown.com/lock-strategy.html
    I Have Cookies
    Reputation: ae111black's Avatar
    Dec 2008
    I use a Specalized old cable lock with the "kevlar weave" over it had it for years (about 13) for my neck of the woods it sufices I lock my bike to the back of my truck or what ever im locking it to at the moment...... dont need worry about work I park my bike in front of my desk! (My Boss is cool)
    The most important thing is what God thinks about it. He will have the final say. Joshua Stinebrink
    ____
    Kimo
    Reputation: AlliKat's Avatar
    I go for a '92 MB-3 with second stage hand me down (too worn out for single speed which gets worn out parts from good bike) parts. I don't expect any trouble.; there are many better options close by.
    Oh sh!+ just force upgraded to cat1. Now what?
    Best thing about an ultra marathon? I just get to ride my bike for X hours!
    bike the planet!
    Dec 2008
    I live in a pretty low bike theft area so I use a 3ft length of chain from the hardware store w/ a swanky cloth cover I sewed for it (so you can't really tell that it's hardware chain and not hardened security chain) and a master lock. I usually don't have to leave my bike locked up unattended for more than a few minutes though. Sometimes if I'm just running into the local meat market or the bank on main street I just leave the bike leaned up against the front window of the store. I'll usually clip my helmet around the rear rim to make ride-off theft a little harder but so far no one has even tried to molest my bike(s)
    Reputation: louisssss's Avatar
    what would be a good price to pay for a lock to lock up my entry level mtb $600 Specialized P.1 AM in NYC(dangerous?)?
    RH SL Pro
    Quote Originally Posted by louisssss
    I would go for as good as you can afford - ideally something like the Kryptonite New York Fahgeddaboudit U-lock, (~ $100) and a secondary lock of some sort. Sure it seems nuts to spend $150-$200 to lock up a $600 bike, but using cheapo locks is a sure way to lose the $600 you spent on the bike. I use a similar setup to lock up my $400 commuter (Kona Smoke) in Toronto, which is bad for Canada but nowhere near NYC for bike theft, and have had no problems.
    One of these:
    http://www.abus.de/us/main.asp?Scree...=4003318100222
    But I have a question as well. What's the lightest lock that affords realistic protection? The Abus (and the Krypto equivalents) is like carrying a rock.
    Depends on the area. I like the cheap light locks, keeps the innocent thief away. If you are in a high crime area try to keep your bike inside, a lock will not protect components (Saddle, rims, crank, etc.)
    http://www.amazon.com/Kryptonite-Kry...7718030&sr=1-5
    how easily could someone break through this lock?
    RH SL Pro
    Relatively easily, because the shackle's not very hardened compared to their Evolution and New York series. For $15 more, get this one: http://aebike.com/page.cfm?PageID=30...ils&sku=LK4212 Double-deadbolt locking, hardened shackle (and thicker, I believe), more keys.
    Personally, I do have one of that Kryptonite "Standard" U-lock, and if I'm just running into my landlord's office on an arterial street to pay rent, which takes two minutes, I'll use it for that. But if it were going to be there for an extended period of time, or on a predictable timeframe, I'd haul my New York ML18, which is built like the Fahgeddaboudit but in a longer shackle length.
    Like someone else said, get the best you can afford. The standard New York U-lock would be around $65 and the stronger Fahgeddaboudit version is about $10 more.
    Also, use your lock to maximum possible advantage, and consider making things even tougher for thieves by using two separate locks if the situation allows for it: http://www.mechbgon.com/lock If you only need full protection at one specific destination, such as your workplace, you can just leave your heavy lock there, and haul your secondary lock with you for lower-risk errands.
    ^^ thanks, whats better to lock up with a U-Lock?
    frame + rear wheel + meter w/ Kryptonite cable 1007 to snake around front wheel/seat/frame
    or
    frame + front wheel + meter w/ Kryptonite cable 1007 to snake aounnd rear wheel/sear/frame?
    also, the fuggetaboutit lock is so damned small i dont even know how id be able to use it to lock around anything, i'm currently looking into http://www.amazon.com/Kryptonite-Bic...719571&sr=1-20 w/ the 1007 cable.
    do krptonite locks come with the bracket to mount to the bnike?
    RH SL Pro
    or
    I would use the first method: lock frame & rear wheel (because the rear wheel's more valuable and difficult to replace), then use a cable for the front wheel and seatpost. Also, most U-locks wouldn't be able to get both the front wheel & frame plus a parking meter unless the lock has an abnormally-wide shackle.
    The Fahgeddeboudit is too heavy for the existing Kryptonite bracket, is what the Kryptonite rep said at BikeForums.net. I think you're right, it's a relatively small U-lock and you'd probably lock just your frame and a parking meter with it, which is why I have the ML18 variant that's got enough shackle length for the rear wheel, both chainstays or seatstays, and possibly my front wheel as well. But the ML18 is a 7.5-pound lock, so it's no fun to be hauling THAT around everywhere, especially if I've just bought 25 pounds of groceries
    The standard New York U-lock and the models below it do come with bike brackets, last I knew of, but in many cases they're not very usable because of limited space in the bike's frame, especially if you've got waterbottle cages installed. I figure on carrying my lock in a trunk bag, a pannier, or a backpack.
    is this: http://www.amazon.com/Kryptonite-Sta...722091&sr=1-72
    equal to the New york 3000 that people are calling?
    on their website it just says New York STD, are we all talking about the same thing here? ^^ looks like what i'm planning to get so far + a 1007 cable to lock up seat and front wheel
    RH SL Pro
    Yeah, I think they just changed its name, is all.
    http://www.amazon.com/exec/obidos/tg...X0DER&v=glance
    hows this (Avenir Tightrope Cables (12mm / 7 feet) ) for using to loop around seat + helmet + front wheel along with the NY standard (3000) lock? i will be putting the two ends of the security cable into the U.
    RH SL Pro
    Looks all right to me, as cables go. But cables are extremely vulnerable... I lost my keys once, and simply broke my cable by pulverizing it, using a rock with a sharp corner as an anvil, and a rounded rock as a hammer. That's caveman technology, and it didn't take long. So you definitely want the U-lock to be what's anchoring the bike to a solid object, and the cable just deters thieves from walking off with low-value parts, is all.
    Quote Originally Posted by mechBgon
    exactly what i was going to do, u think my front wheel/seat/$160 helmet will be safe with a 12mm steel cable from Avenir (raleigh) ?
    i'll be using the NY standard lock to lock the frame + rear wheel to secure pole.
    RH SL Pro
    I use 5/16th hardened truck chain and a 5/16th hardened contractor grade Masterlock. 3ft bolt cutters won't cut it. I tried. You'll be needing power tools. None of my bikes are <$1000 so it's important for me to lock securely. I also don't have quick releases on any of my bikes except my Pugsley, but it never gets locked up.
    how are avenir cables? i want to order from amazon (cheapest for U-lock + cable) and Avenir seems to be the cheapest per length/thickness.
    how does Avenir cables compare to Kryptonite/OnGuard Akita?
    RH SL Pro
    They should be fine as a secondary theft deterrent, such as for your front wheel.
    Reputation: dcc1234's Avatar
    Nov 2008
    I use these. Makes locking up easier. I am still using the older Kryptonite locks with the bad key design. Been ok so far.
    how do those work exactly? ^^
    can i still remove my seat easily?
    RH SL Pro
    bi-winning
    Quote Originally Posted by dcc1234
    Those seem to come with their own key design - cool.
    I replaced my QR skewers with the kind that need a 5mm allan key to remove (at least you need a tool, vs bare hands to remove them), but those take it a step further.
    i think i'll just stick w/ using a security cable (about 7 feet, 12mm thick) to lock up my F wheel, helmet, and seat.
    RH SL Pro
    just placed the order for the Kryptonite NY Standard (3000) lock + an Avenir 12mmx7feet security cable to lock down front wheel/seat/helmet.
    ordered from amazon 58+8+5tax = ~$72 free shipping.
    anyone know kryptonite's guarantee on locks and what to do if my bike were to be stolen while locked up?
    RH SL Pro
    Caution;  Merge;  Workers Ahead!
    Just my 2 cents worth on the subject.
    1_ Cables should never be used as a Primary means of securing any bike that you would like to keep.
    2_ U-locks are better, but still easily dispatched w/ a car jack or simple pipe to pry it open.
    3_ Case-hardened security chains are probably the most secure, if used w/ a good quality monobloc style padlock.
    Currently BikeRegistry has some on sale for 35 bucks each, including delivery by US Postal Priority Mail.
    Quote Originally Posted by djetelina
    u made an account here so u can advertise this site or something?
    -i didn't say i was using a cable as the only means of securing a bike.
    -the Kryptonite U lock is pretty much the best on the market right now. find me one better than the New York lock for $58.
    -if i wanted a big chain, i'd go for the kryptonite NY Chain
    RH SL Pro
    I live in a moderate bic crime area. I use a medium size stainless steel chain lock with a bic alarm. I park my bic at crowded area, In the past.use to lost component like bell or side mirror and with some jerk playing off my gears. But after i install a bic alarm. No component lost cos the moment they touch my bic,the alarm will trigger and will scream like hell asking them to 'Get away from me!'
    With the crowded staring at those jerks, off they go from my bic.
    Quote Originally Posted by shimano4
    I leave my bic in the front top pocket. That way it is easy to access when I need to write something. (or are you on about lighters, or razors i can't tell_
    nnn
    nnn is offline
    Reputation: nnn's Avatar
    Feb 2005
    One of these for me
    + A Kryptonite D-lock
    "Life begins at 140" Richard Burns
    http://www.nikolay-k.com
    Do u have something against me? Or maybe u forget to take yr medicine?
    NY lock for frame, 6 foot x 12mm thick security cable from Avenir for F/R wheels, 6 foot x 6mm thick security cable also from Avenir for seat and helmet.
    i live in NYC, i fear the worst...
    RH SL Pro
    sax
    sax is offline
    does this chain come with a lock?! or just the chain itself?
    Quote Originally Posted by sax
    i wouldn't use that chain, especially if ur bike is real expensive or you're in a med crime area or worse. i'd stick with the name brands because of their harder steel material and guarantee policies.
    for $35, i dont think u will be gettin much for your money... with locks i'd rather not cheap out on.
    RH SL Pro
    good u lock, but what will u be locking with that cheap chain? i'd say find a long, thick security cable for the wheels and get a shorter, thinner cable for the seat & helmet.
    thats exactly what i do, i use avenir's 6mm and 12mm cables for the seat & rims, respectively.
    RH SL Pro
    sax
    sax is offline
    i'm planning to lock up my front wheel with that chain.
    and, what type of lock do you use with your avenir cables?
    Reputation: kiatkiat's Avatar
    Anyone had use a O-Lock here?
    It is good if combine with a chain lock.
    When it's time to go, is time to go.
    Fate rarely calls upon us at a moment of our choosing
    that chain would be secure enough for wheels, but that same thing can be achieved with an $8 security cable, check out 6 feet by 10-12mm thick.
    and i dont see that o-lock very useful, again, i'd stick with the Kryptonite NY U lock + thick security cables for wheels
    RH SL Pro
    sax
    sax is offline
    ok, so how about this cable: http://www.amazon.com/exec/obidos/tg...X0DER&v=glance
    and this lock: http://www.amazon.com/SeaSense-PADLO...761671&sr=1-21
    for my front wheel?
  67. #67
    Is there a good reason why you're stinging out this far for security of your bike? Really stingy.
    In all honesty that padlock is more compromised than the 12mm cable, and as if a 12mm plain cable is a deterrent. Both the cable and padlock can be defeated by bare hands... really, I've tried. The cable can be strip/burnt of its vinyl coating (since after you snap the cable the coating still has plenty of flex to hold the cable together) then the cable folded onto itself multiple times until the all wires of the cable snap away; that padlock can be twisted along with the cable until the shackle on the padlock snaps with bare hands.
    If you're looking to keep costs down for securing the front wheel in lightweight form, then I can see a couple of viable options on Amazon:
    - M-Wave (Wal-mart) armoured cable lock. $13, short? cable for front wheel to frame/locking point if you're not looking to spending money or dealing with the weight of a mini u-lock.
    - On Guard 5026 armoured cable lock. $22, 1000mm x 20mm, just long enough to maybe loop the front wheel and frame to the locking point.
    I'm lucky enough to have found a stockpile of MasterLock Quantum Armoured 30 locks for AUD$20-40 at my local hardware store. I can't remember an exact number, but all I know was they were CHEAP.
    All that said, cables are still the bottom end of the security scale, and many hover in the inadequate/non-deterrent zone simply because of limitations of cables to attacks. Not saying all cables are hopeless, as always it really depends on the area, duration of being away.
  68. #68
    cable is good, i have the same.
    lock, i have no experience with....
    you will need another cable to lock up your seat tho, that cable is too thick to fit through the rails of a seat
    RH SL Pro
  69. #69
    Reputation: MrFahrenheit's Avatar
    Im going to Georgia Tech in the heart of Atlanta. I would love if i could keep my bike in the dorm room, but theyre soo small.
    So my question is: how much do these locks weigh on average? I live in a very safe suburb so never really needed a lock so can i expect to be extremely weighed down around campus or can i find a very safe, reasonably weighing lock.
    Thanks,
    MrF
  70. #70
    if i had to guess, my Kryptonite NY lock weighs ~10lbs, 7ft x12mm thick security cable weights ~2lbs. they're not light.
    with locks, u do not want to go the "light" route. theres just no way around solid hardened steel. if u want light, then u must not want your bike
    RH SL Pro
  71. #71
    Alright, noted ha. Ill keep that in mind. I just wish i could squeeze it in my dorm room, but i dont know if thats gonna happen
    http://www.housing.gatech.edu/assign...cfm?BldgID=015
  72. #72
    After watching a video on youtube on how easily chains are clipped with large cutters, I'll avoid any chain. Chains are especially vulnerable when they are low to the ground and a theif can apply more leverage.
    http://www.youtube.com/watch?v=VC3hF...eature=related
  73. #73
    sax
    sax is offline
    Quote Originally Posted by MrFahrenheit
    yeah my dorm is 11 feet by 14 feet, but there is a strict policy about no bikes in the dorms. they must stay outside at all times. it's a bummer.
  74. #74
    I ordered one just for the hell of it. $35... can't lose. Comes with a great lock that only has room for the chain so the lock can't be cut. I have an onguard chain lock also and I wouldn't say that is any better or worse.
    Great value and not "cheaping out" IMHO.
  75. #75
    MrFahrenheit and sax, sounds like you guys need a put together a beater-looking bike. Either that or a folding bike??
    Cos locking up a nice bike out in the open all-day, every day, open to recon by thieves to plan which bikes to pick up at which times of the week; a non-beater profile is going to attract attention.
    You can have good quality parts, you just have to ugly-fy the bike and its parts to Tacky-Ville. Nothing a like random rips of '90s fluoro tape, a vomit of vivid ano, electrical tape, and not at all tasteful nerd-core reflectors.
  76. #76
    sax
    sax is offline
    Quote Originally Posted by ryball
    *image*
    alright thanks, but i ended up picking up another one.
  77. #77
    how much is ur bike worth? a $35 lock isn't going to get you much. theres no such thing as a "good deal" when it comes to securing your bike...or anything else valuable.
    RH SL Pro
  78. #78
    All I'm saying is that it is no better or worse than similar offerings from OnGuard or Krypto. I never lock my bike up in questionable neighborhoods anyway.
  79. #79
    cool go for it, all I'M saying is that i value my bike more than having only $35 of insurance for it...
    RH SL Pro
