Let's see your flaps. Mudflap galore.- Mtbr.com
Results 1 to 2 of 2
    I'm feeling dirty, you?
    Reputation: jonowee's Avatar
    I've been breezing through the commuter section of RBR and found a high amount of added mudflaps to existing fenders.
    How do you like your fender-mudflap set up?
    High with long flap, high with short flap, or low with short flap? Outside that of Brown Teeth's kit.
    I've been running SKS Beavertails flapless for awhile now, yes they are not full coverage but they are wide for 700c. I just put on a mudflap on the front this morning but that still needs so tweaking, and the rear I'm unsure how to go about flapping the rear; so here's where your photos will help give us ideas. This until I get new full coverage fenders with stays some time farther on in the future.
    No-Brakes Cougar
    Reputation: Gary the No-Trash Cougar's Avatar
    I used to use the SKS beavertails....
    ....and I couldn't get the coverage I wanted either. AT least not on the front. So I switched to Planet Bike's Hardcore fenders. Full coverage plus mudflaps. And if you have built in eyelets for the stays, it's a cinch (and even if you don't you can rig something up fairly easily).
    R.I.P. Ronnie James Dio ~ July 10, 1942 May 16, 2010
