Lenz Heated Socks, Insulated Boots or Both?- Mtbr.com
    high pivot witchcraft
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    Any of you commuting beasts use these when the temp drops way down?
    I normally commute in my Solomon hiking boots (goretex but not insulated).
    I think I am going to have to throw down on either the heated socks or new insulated boots. I am thinking the latter, since I already have heated footbeds in my ski boots (I won't be able to multi task the heated socks). At $390 CDN I could buy some awfully nice insulated boots.
    What are you guys wearing on your feet for the super cold?
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    Insulated 5.10s or boots plus toe warmer packs if needed. Keeping your legs warm will also keep your feet warmer.
    Reputation: ghettocruiser's Avatar
    Quote Originally Posted by ghettocruiser View Post
    Shimano MW7s, with an aerogel insole, *and* an electrical heating coil with an external battery pack. Sometimes I seriously put a shoe-cover over top, but things then start to get too wide for my crankset.
    Failing all that, and sometimes it does, if I don't have the shoe covers on, I'll get off and run up on a hill or two.
    The headed insole elements I got from aliexpress for about $10 and use any USB phone charger pack (i.e. from Costco or Bestbuy) as a battery, which avoids the sketchiness of sourcing no-name lithium batteries from overseas. They kick off as much heat as the big-dollar Hotronics kit I used to have, albeit with more assembly required.
    The above statements have not been evaluated by the Food and Drug Administration
    CB of the East
    Reputation: bedwards1000's Avatar
    I bet you can get a really nice pair of boots for $350 and have some money left over for many years worth of hand warmers.
    It probably depends on the temps you ride in. If you are below 0F a lot you may need the heated socks. Otherwise I'd go for the boots.
    (It looks like there are 4 other threads about heated socks in the "Similar Threads" section below. )
  1. Heated insoles or socks?
    By headwind in forum Fat bikes
    Last Post: 11-18-2017, 08:15 PM
  2. Heated insoles/socks?
    By _CJ in forum Apparel and Protection
    Last Post: 01-08-2017, 04:33 PM
  3. do those heated socks really work?
    By Chemandy70 in forum Fat bikes
    Last Post: 01-29-2014, 09:06 PM
  4. Heated socks???
    By rmac in forum Turner
    Last Post: 12-14-2005, 08:53 AM
