Hydros and winter salt- Mtbr.com
Results 1 to 6 of 6
    Class Clown
    Reputation: dundundata's Avatar
    Have used bb7s the last few years, they always get trashed after a long winter with all the road salt.
    This spring I upgraded by bikes to Zee brakes and said goodbye to mechs. I wonder how they will holdup through the winter. Obviously they are well sealed, ceramic pistons, and they don't have that extra mechanical lever sticking out.
    I guess what I am trying to decide is run the Zee's or swap out for something cheaper like Deore or slx.
    Jul 2014
    have you considered getting a beater for riding during the winter?
    97 specialized rockhopper.- urban beater
    2013 GT aggressor 3.0- urban assault vehicle
    Class Clown
    I have a beater but my commuter I ride too much so I throw on cheaper/old parts for the winter
    Reputation: Mr Pig's Avatar
    Quote Originally Posted by dundundata View Post
    It doesn't make any difference to them. Of course you will get more surface corrosion from filthy winter roads but the operation of the brakes should be unaffected.
    Human Test Subject
    Reputation: Volsung's Avatar
    It depends on where you ride, but mineral oil can get gross in the cold. I had sram guides, which use DOT fluid but after 2 years the pistons seized. I'm not sure if ceramic pistons can, but the brake around it is probably aluminum.
    TRP spykes have a cover that can keep a lot of the grime out.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Hold on to the Bb7s
    and get some aluminum rotors & you should be good..
  1. Mineral Oil Hydros in winter? Or DOT?
    By FlashExplorer in forum Brake Time
    Last Post: 05-29-2016, 08:29 AM
  2. Winter commuters, minimizing salt damage?
    By cr45h in forum Fat bikes
    Last Post: 09-26-2015, 10:59 PM
  3. Winter road trip with bikes-best way to deal with SALT??
    By theDeleman in forum Minnesota, Wisconsin
    Last Post: 02-19-2013, 12:36 PM
  4. Winter riding...salt?
    By Visionist in forum Beginner's Corner
    Last Post: 12-03-2012, 02:26 PM
  5. Hydros in winter, which ones work?
    By ericpulvermacher in forum Brake Time
    Last Post: 11-28-2011, 12:28 PM
