Front rack on fork without eyelets- Mtbr.com
Results 1 to 8 of 8
    Ok, so I need to fit front rack on mtb fork that has no eyelets. This fork is RockShox XC 32:
    https://www.bike24.com/1.php?content...6:5417::65:224
    Do I have a solution that would look at all meaningfull?
    Considering I need to fit mudguards as well maybe I am better just changing the fork
    since 4/10/2009
    Reputation: Harold's Avatar
    Your choices are limited.
    Old Man Mountain Sherpa would work.
    Old Man Mountain Front Pannier Racks For Any Bike
    Jan 2014
    I use this on my commuter with a fork. Secured with ubolts and quick release skewer. Journey Suspension & Disc Lowrider - Lowrider Racks - Racks - Products - Axiom Performance Gear
    Positively negative
    Quote Originally Posted by snailspace View Post
    I've installed two of those and wasn't really happy with either, in fact one came right back off. The QR likes to slip under braking, the u bolts are had to get adequately tight (and I have seen one snap), it's hard to get bags to fit well, and they make removing the wheel a huge pain. I generally like Axioms stuff but that thing is a miss.
    Zefal also makes a suspension compatible rack, but if the bikes trail days are over I recommend switching to a rigid fork.
    Quote Originally Posted by big_papa_nuts View Post
    I also found this: Thule Pack ?n Pedal Tour Rack - Thule
    but it doesnt suit my style
    Looks like rigid fork will have to be the answer, especially taken into consideration how sexy this look like: tubus - Tara
    Jan 2014
    I use the axiom racks with respective panniers and have no issues carrying up to 15lbs a side without any issues. Ther's a D ring a the bottom for the hook and 2 tabs to prevent sliding around. The QR skewer provides the load bearing. Only drawback is you have to remove the skewer for flats or tire changes. I chose the axiom as I would strictly be using panniers.
    Do you know will it fit Ortlieb panniers?
    Jan 2014
    The axiom panniers I have a hook on the bottom that attaches to really any spot, and can be moved up depending on rack height. 2 hooks on top secure pannier to top. Bungee cord can be adjusted for appropriate tension. So if you have something similar it should work. Hope the pic of the pannier gives you an idea. Front rack on fork without eyelets-020.jpg
  1. Older KM fork front rack
    By leeboh in forum Surly
    Last Post: 07-02-2014, 02:02 PM
  2. Front rack without mid fork braze ons
    By jasevr4 in forum Commuting
    Last Post: 03-20-2014, 09:41 AM
  3. Front rack for a 9:Zero:7 aluminium fork?
    By hknivers in forum Fat bikes
    Last Post: 01-02-2014, 06:57 AM
  4. OMM FRONT rack on Pugsley fork
    By nm13 in forum Fat bikes
    Last Post: 10-29-2012, 06:49 AM
  5. Eyelets or no Eyelets, CNC or not, for KinLin Rims?
    By BH2006 in forum Wheels and Tires
    Last Post: 03-06-2011, 11:41 AM
