Fixie Sizing Help- Mtbr.com
    Racer
    Reputation: metalMTB's Avatar
    Fixie Sizing Help
    I posted this over in the singlespeed forum but I was told I would get a much better response over here...
    I am planning on either getting an Origin-8 Uno or a Felt Brougham as a commuter bike. If I went with the Uno I would definitely get a 59cm but the Brougham only comes in a 58 or a 61. I have no way of sitting on this bike before I order it. My question is, will I be uncomfortable on a 58? I'm also afraid the 61 will be too big. What do you guys think? Should I go for a smaller or larger size for fixed gear commuting?
    BTW I am 6'2" and I ride an XL Giant Reign ATM.
    Thanks.
    http://www.feltbicycles.com/USA/2010.../BROUGHAM.aspx
    http://www.origin-8.com/product_deta...o&cl1=BICYCLES
    Try and find a bike at LBS with similar geometries and test ride.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Almost impossible to answer given the information. I'll agree with homebrew.
    Reputation: pushinpixels's Avatar
    The fit calculator from Wrench Science is helpful. You need to register first.
    https://www.wrenchscience.com/Login....=R&stylecode=R
