Fender mounting- Mtbr.com
Results 1 to 6 of 6
Thread: Fender mounting
    Fender mounting
    I have SKS Crusher front fenter which reqires a star nut mount. I built a commuter with an a old SID fork with only 3/4 inch opening at the bottom of the tube. Can't find a 3/4 star and wondered if anyone had a suggestion for an alternative expansion nut. Also wonfer if the SKS mounts for the ShocK Board might work. Tim
    Bedwards Of The West
    Oct 2007
    Does it have a 3/4 inch opening at the bottom, and then it opens up to a full size tube, or is the whole tube 3/4 inch internal diameter?
    If it's an opening and then a larger diameter tube, you could drop a fat washer and a nut down from the top of the fork tube.
    (no excuse for that either)
    Or hammer a star nut all the way down and use a longer bolt.
    thinking of gluing a dowel into the fork bottem
    weirdo
    Reputation: rodar y rodar's Avatar
    I`d go with Schmucker`s method.
    Recalculating....
    can't most of the tube is 3/4
