This is a dynamo hub/light kit I like!- Mtbr.com
Results 1 to 11 of 11
    since 4/10/2009
    Reputation: Harold's Avatar
    NAHBS 2014: Harvey Cycle Works? Awesome Connector-Less Gravel Grinder Dyanamo Light Rig
    Even better, this guy is local. A friend of mine had him build her commuter, and he's friends with a couple other people I know. His day job is with Andretti Racing.
    Reputation: sunvalleylaw's Avatar
    Jun 2010
    That does look cool.
    Jul 2013
    very cool, looks awesome
    awesome.....reminds me of a VW
    Jun 2013
    I don't get it.
    The lights are mounted too low everybody knows you want them up on the bars.
    It's nice that there's no exposed wires, but modern Euro bikes do the same thing by running the wires inside the frame/fork.
    And dynamo lights are great, until you're not moving, and still want to be seen...
    since 4/10/2009
    Quote Originally Posted by Bimmer74 View Post
    I don't get it.
    how does everyone know you want them on the bars? How do you reconcile something like this, that puts a light far lower?
    Problem Solvers | QR Nut Light Mount Hack from Edelstone
    Mounting Lights from Peter White Cycles
    Lovely Bicycle!: Front Racks and Elegant Light Placement: Mission Impossible?
    The lack of wires is in the CONNECTION TO THE HUB. Harvey didn't design that - he's using off-the-shelf parts for it. I happen to really like the system. I've messed with some dynamo hubs and I'm not a fan of the wire connection from the bottom of the fork leg to the hub, and all of them have had the cable routed internally through the fork. Putting the current through the dropouts is very slick and clever, and it'd be nice if more dynamo hub manufacturers start doing this.
    What he designed is the light mount/placement, which I also like. It's a really solid mount and gets it out of the way.
    Nobody said this should be the ONLY light setup you use. Most folks in this board don't skimp on lighting.
    Jun 2013
    Quote Originally Posted by NateHawk View Post
    Mounting the light higher casts light down the road better, and it's more visible, period.
    Point taken. Having lights mounted too low is certainly better than no lights, and the more lights, the better...
    For what it's worth, my light's on my bars and I wish it wasn't. I get much more reflection off my shifter cables than I'd like, which hurts my night vision.
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Re: This is a dynamo hub/light kit I like!
    Front light goes on the fork. Fact.
    --Lars
    Attached Thumbnails Attached Thumbnails This is a dynamo hub/light kit I like!-uploadfromtaptalk1402072444791.jpg
    --Peace
    since 4/10/2009
    Thank you. It is a very practical location for the light.
    Quote Originally Posted by Lars_D View Post
    --Lars
    Bicyclochondriac.
    Actually, having the light farther down (away from your line of vision) casts more shadow and lets you see features and texture in the road. This is also the upside of bar mounted lights over helmet mounted ones.
  1. Dynamo Light Question
    By Lagopus Lagopus in forum Lights and Night Riding
    Last Post: 01-15-2013, 10:20 PM
  2. my new dynamo light!
    By HomeGrownSS in forum Lights DIY - Do It Yourself
    Last Post: 12-16-2012, 02:33 PM
  3. Dynamo light + dynamo GPS (or phone) charging. Bye-bye batteries?
    By robdeanhove in forum Lights DIY - Do It Yourself
    Last Post: 11-04-2012, 02:38 AM
  4. My first light - dynamo powered
    By nicknoxx in forum Lights DIY - Do It Yourself
    Last Post: 02-29-2012, 12:13 AM
  5. Street Dynamo Light
    By mrradlos in forum Lights DIY - Do It Yourself
    Last Post: 01-10-2012, 09:07 AM
