Does this look right?- Mtbr.com
    Jan 2014
    Should that bit for the bottom bracket be threaded in more? Just curious as I was giving a bike a look over.
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    I think it is OK if there is no play when you grab both pedals and try to rock back and forth.
    Jan 2014
    No play, so I assume it ok.
    Positively negative
    Looks fine to me. That side just bottoms out on the cartridge so it usually won't go all the way in. In fact that tend to crack if they go in too far, but that won't happen if the right parts are used and the frame was made correctly.
